You and Jerry should talk, you could amuse each other for hours. Welcome to Marlin, there are alot of welders here. I have been in it for 21 years.
Is Jerry junya92toy? I was reading a couple of the other threads and he has offered up quite a bit of good sound advise from what I have seen.
I got on for ya.How do you feel about stitch welds or "stack attack"? By that i mean your laying a bunch of individual beads on top of each other as you go along your contact patch. I was told it has the same amount of strength as a continous bead so long as your burning it in very hot and you never let the previous bead cool down so they fuse together. It just turns out so much prettier in my opinion and i have not seen any impurities come up as long as it's hot and clean. I've seen it done on comp buggy cages so i figured i'd see what you guys think or you in specific sense you tossed the offer up! And it's cool to see people offer this service man, especially a newb on the site! Thanks!
ok so im welding 1/4 inch flates in my frame and gussts i have a lincoln 125hd runs off 110v i run .035 flux cored wire i have the voltage maxed out on E and a wire speed of almost 2 i run one bead down the seam burning the 1/4 into the thinner frame metal i grind that down and run another pass over it them just smoothe that one over so it looks good ive had people tell me my welding skills are pretty good and am taking a class right now to get cirtified my question is am i getting ample penetration with my welder to be structurly sound in my frame
Ya the " stacked dime" look is stupid, craters like the moon, and cracking, I weld with c02 at home, hot and fast, no bead look at all, it flat and smooth. But when you weld right with a continues bead, and a certain gas, you will get ripples and have that effect which is fine. Just triggering it in, to get that is stupid.
bigred, have you scoped out, and chimed in on the welding thread? tons of info there.... i like reading it for the debate and opinions, etc..... it's good stuff to know.... i have nothing to contribute to that thread though, just reading
Started by Suprarunner « 1 2 » Engine
Started by Homefries General 4WD Discussion
Started by Talon84x4 « 1 2 » General 4WD Discussion
Started by DD85runner For Trade or Barter!
Started by 808newbie New Member Check-In!
