what size of ring and Pinon do i have?
Started by 93REDCRAWLER, March 26, 2011, 11:06:53 AM
93REDCRAWLER
what size of ring and pinon do i have in my rear differential?
its a 93 toyota pickup.
stock ifs, stock rear axle, stock gears,
need anymore facts just let me know.
thanks for the help in advance
86rustbucket
toyota 8 inch      probably 4.10 gears
if your ordering gears you need to specify if its a 4cyl. or v6
93REDCRAWLER
Quote from: 86rustbucket on March 26, 2011, 11:10:40 AM
its a 4cyl, i thought i had 3.56 gears and i was going to regear to 4.10's with a locker but if i already have it then ill just throw in a locker.
Are you sure the gears are 4.10?
4RunnerChevy
Look under hood and find the label.  Look for your axle code and then decipher it.
86rustbucket
why waste money on 410s?   you can grab a complet 3rd from the junyard for $70
if its got a 5 speed then they should be 410s   you can check the door tag like above or you can pull the drive line off and check the paint code.  410s have a dab of pink paint in the center of the flange
Yeah I agree I would just pick up some junk thirds.
