stock 85 runner needing to grow up ~
Started by coloradobasshead, January 31, 2011, 08:01:39 PM
coloradobasshead
Hey just wanted to introduce myself , new to the forums , Denver CO here - just bought a 1985 4runner , with a  blown engine ,  week ago had a reman 22re put in it and she is on the road ! Now its time for her to grow up a bit . Got to work out a lot of kinks , I hear marlin is the bomb sizzle  ~so here i am to learn ~
twistedtoy92
welcome to  :turtle:  :welcome:
Now get some posts up so you can get some pics of your rig on here!  :beerchug:
Coastie
coloradobasshead
Thanks guys ! My rigs just stock .. for now , with a rattle can paint job by the previous owner , But has been taken care of thru the years , got a  pile of receipts came with the runner , and get this, the original window stick  from off the lot, the owners manual , and an old 1985 repair manual that is the size of a phone book ! I was stoked to see that !
coloradobasshead
so my springs are shot , no more curve they are  flat as a board, so im putting this on the top of the long  list of  upgrades , 4-5 " lift  soon as I can ill get some pictures up ,  Get you yota gurus to shine some light  on the correct way to build this out right, only thing I'm bummed about is its an automatic , so down the road I will have to address this issue, From what i been told , a shift kit and some new gears will help out a whole lot,  but well cross that bridge when we get to it !!
coloradobasshead
Thanks guys for the warm welcome !!
ya i was looking at all pro  "extreme lift kit "  , im hearing a lot of guys that swear by there lifts , and it comes with the hysteer brackets , just need the box i guess , and some drive shaft rework and  were golden !
coloradobasshead
86bobbedtoy
Quote from: coloradobasshead on February 01, 2011, 08:28:15 AM
thats a great start,
if you got the $$$
coloradobasshead
not really , but im tired of taking the less quality route - this one im going all out- and the first time, if i dont have the mulla for the best, i will wait till i do-  just have to learn what the best is lol i got a good start , hardly no rust and a brand new reman in it ...
Sparkplug
If it was me, id fix the truck, get some good tires, and wheel it stock, while you research all over here and pirate. When you dinally start struggling on the trail, instead of buying a lift kit, spend the money on a nice welder and a grinder, and do it all yourself, exactly how you want.
coloradobasshead
is it that easy  Spark ? I have read some forums where everything was mad custom , but im sure the guys building it came from a mechanical background to be able to pull of some of the work they did ! Im def a DIYer but there is a line that you have to draw when it comes to specialties ..  lol
coloradobasshead
speaking of welders ,  all the work that is done on these trucks are just stick welders right?
you can use any welder you can find that can weld up to .200 inch thick mild steel.
coloradobasshead
so idealy a 220 v mig welder would be key, and a good angle grinder ! ha
any thought to rebuilding your stock springs with some F150 2wd springs?? its very easy, requires NO WELDING, and can lift your truck 3 inches for under $100
coloradobasshead
this is new to me ! talk to me coyote !!
coloradobasshead
where do i get these springs from ? they will fit the stock length of the existing springs?
coloradobasshead
coloradobasshead
Thanks ! the color is a rattle can , looks decent there , but kinda of brighter in real time ,not so pretty , im working on getting that changed, but really good body , clean , underneath , just a tiny bit of rust right at the wheel fender, which i want to just cut out , gotta get some shots of the new engine .
87hillbillyoter
1987 SAS'ed toyota 4x4 pickup 22re swap
build up- http://board.marlincrawler.com/index.php?topic=75111.0
mudmaster
Time to go wheelin!
