chevy springs question(part 2)
Started by toyodaaddict, January 25, 2011, 07:58:00 PM
toyodaaddict
i hate to ask but i didn't see it in the faq. are you guys running the chevy springs  the same direction that they came out of the chevy ? i noticed one end of the springs is higher than the other and it made me wonder
Nimyad
i did. usually one side of the spring is softer so if you don't run it that way you'll have axle wrap. i have no idea if the chevys have a soft side though.
toyodaaddict
one more  question. im having trouble getting a 100% accurate measurement. if one of my spring hangers ends up 1/16" of an inch ahead of the other will i be ok?
fade
should be ok your shackel will be a lil off. try to get it straight though
86 mini truck 18" rays
09 highlander
70 suburban
86bobbedtoy
ur good,
cant argue with 1/16th of an inch
toyodaaddict
Quote from: 86bobbedtoy on January 29, 2011, 10:28:45 PM
ur good,
cool, thats kinda what i thought
