Author Topic: clunk clunk . . . .clunk clunk . . . cant figure it out  (Read 3025 times)
85yotanh
  • Turtle Points: -1
  • Member since Jan '10
« on: Jan 21, 2011, 03:48:13 PM »
So i rebuilt my front axle a few months ago. . . before i rebuilt it there was a clunk while wheeling or turning at slow speeds. I figured it was the axle and it would dissapear after the rebuild. Post rebuild . . . as in the first time i drove it around the yard it still made it. . not as bad but still present in some situations.At that point i checked all my torque specs and crap of that nature . . .it was all good. My first few wheelin trips it was a mixed bag sometimes terrible sometimes not there at all, so i decided to tear back into the knuckles, all checked out well no problems re-torqued everything and i thought i was good. nope still clunking while wheeling but only from time to time and for the most part never. Last night i was pulling out of my buddies house and it started but bad. with every bump a series of clunks with every stop sign and turn it would clunk ( its winter in nh so frost heaves and back roads = clunking non-stop). At work today when i turned the wheel just before max turn it double clunked and then again when i released it. Im stumped, I got home and it was dark so i did a quick check of my brake, my wheel bearing, my tie rod ends, and it all checked out  . . . What am I missing?
Thank you in advance for any info you can provide
Thanks,
Ben
Sparkplug
  • Turtle Points: -130
  • Male Posts: 2,046
  • Member since Jan '08
  • Doin it Standing Up
possibly bent front axle
85yotanh [OP]
  • Turtle Points: -1
as in axle tube or shaft? because i feel like a bent axle shaft would be super noticeable
Sparkplug
  • Male Posts: 2,046
Tons of ppl dd rigs with bent axle housings in front and never know. Toy front housings are not very strong stock.
possume22
  • Member since Apr '09
cv joint in the drive shadt is what it sound like to me mine did the same thing
85yotanh [OP]
  • Turtle Points: -1
hmmm it has been snowing for the pas few days and my junk has been in 4wd . . . but then why only on bumps and slow turns you would think it would be all the time . . .i suppose icould unlock my hubs and take it for a spin to find out . . . but it will make the noise at a stand still when i bring it to almost full lock
93REDCRAWLER
  • Turtle Points: 110
  • Male Posts: 563
  • Member since Nov '10
  • You see it we wheel it
X2
85yotanh [OP]
  • Turtle Points: -1
Now is there a way to test that the drive shaft is the noise? because i just took my truck out in 2wd and hubs unlocked which to me says the front driveshaft should not be spinning and there for should not make any noise . . . but it still did! Does that mean its not the driveshaft or is there still a possibility? Im lost
junya92toy
  • Turtle Points: -64
  • Male Posts: 1,500
  • Member since Nov '04
  • Drinking me beer
Maybe its the rear driveshaft?
85yotanh [OP]
  • Turtle Points: -1
so its my front passenger side leaf spring
when i turn the wheel or hit a bump two of the leafs shift on each other ever so slightly and that clunk sound carries through my frame and up into the audible noise i hear while im driving. So today i went under the truck straightened out the leaf squished the clamps back to the leafs and made sure all was tight centerpin, ubolts, shackles, spring hanger. and the clunk continues and its still the spring . . . how do i stop this leaf spring shimmyand clunk?
KDXSR5
  • Poser Shot Extraordinaire
  • Turtle Points: 61
  • Male Posts: 2,812
  • Member since Dec '06
You are positive the center pin is not broken? Mine has broken a few times and it causes a clunk and some weird steering.
85yotanh [OP]
  • Turtle Points: -1
definately something to double check!
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
Are all the slip pads in place? I lost a couple on one spring and it was making a clunk noise.
Nimyad
  • Turtle Points: -1
  • Male Posts: 1,138
  • Member since Sep '10
    • Buy me a cigar
it might be your tie rod ends flipping over, that's what my 81 did, happened everytime i turned. the 94 i just got still does it but you can't feel it as much.
KDXSR5
  • Turtle Points: 61
  • Male Posts: 2,812
OOPS, do you have a source to buy replacement ones? I am sure I can get some at the local spring shop, but I was curious if you had a hookup.
« Last Edit: Jan 23, 2011, 11:10:32 PM by KDXSR5 »
OOPS
  • Male Posts: 2,561
I picked them up at a local spring shop. The ones I posted a picture of are from a vendors web page whose name I will not mention on this BB..
KDXSR5
  • Turtle Points: 61
  • Male Posts: 2,812
Got ya. :thumbs: Seems taking good pics is about all they do. I will cruise on down to the spring shop sometime when I actually have time.
David
  • Turtle Points: 218
  • Male Posts: 263
  • Member since Jan '03
  • I love Marlin Crawler!
x3 on the cv joint. I just went through the same thing, turned out to be the centering ball at the cv joint in the front driveline.
yotaneck13
  • Mr. Right NOW
  • Turtle Points: -52
  • Male Posts: 2,300
  • Member since Nov '09
  • MR. RIGHT NOW
dude he took it out of 4wd and it still did it its not his cv on the dshaft
Bradtoyotas
  • Turtle Points: 57
  • Male Posts: 247
  • Member since Dec '10
It's a bent housing I've had it before!! Pull the knuckle look at were the axle sits in the seal and see how strait it is in the seal more than likely your gonna see a gap were of course oil just gonna run out when you lean the vehicle. Fix is get a chain and a bottle jack and see which way she needs to go back and work it slow then of course in the end put some new marlin seals in it cause the stock ones are trash!! Oh and then gusset the housing from doin it again!! If this is your problem there's the info
Tonka Toys
Last post Feb 10, 2003, 12:21:34 PM
by greenmachine
Last post Aug 22, 2002, 05:36:26 AM
by BigMike
Last post Sep 11, 2004, 09:57:35 PM
by Mike D
Last post Aug 14, 2006, 11:40:48 AM
by BUBBA
Last post Aug 03, 2008, 10:18:02 PM
by 1985SR5
