Are your steering stops contacting? It can sound awful, but it's normal.
thanks I will try that tomarrow and keep you posted. What are the trunion bearings? If everything is bad is the MC kit easy to install? How long do you think it would take? thanks again for all the help.
It is a solid axle not IFS so when the knuckle stops hit the stops there in no movement.
Go to an empty parking lot turn until you hear the clunk and then get out and check underneath. Look for anytning that's touching or doesn't seem right. perhaps the steering stabalizer wasn't set up correctly. just check out everything.I don't see how trunion bearings could make a loud pop. But you could always jack up the front end, take off the tires, dissconnetc the tie rod ends and see if there is any slop, or binding, or chunky feel in your knuckles.all I can think of at the moment.
If the trunion bearings have exploded and are in pieces, I can see them making a loud pop. The whole truck is resting on those bearings, and if one is in piec :Des.
Started by csdpower General 4WD Discussion
Started by zack General 4WD Discussion
Started by jsrusse11 Engine
Started by stone4x4 Parts For Sale
Started by 85yotanh Toyota Pickup/4Runner Tech 1979-95
