New to Toyotas
Started by GreyZuk, January 18, 2011, 09:42:08 AM
GreyZuk
Hey guys I'm totally new to toyotas so bear with me here. I've wheeled the snot out of my samurais :eyebrow: and heeps :stopit: . I'm running over to the coast today to pick up a 1992 4Runner with a 3.0, 5 spd, SAS, with 37" Irocks, and 5.29 diffs.
As of right now, I searched and found that I most likely have the R150 trans and a chain drive t-case. I'd like to either have a single case with lower gears or dual cases. The runner supposedly is coming with a used gear drive t-case. Is there any way to
A. get lower chain drive gearing for the stock case
B. Add the extra gear drive t-case to the existing chain drive unit (in front or behind the chain drive unit???)
C. Donate the chain drive unit to my buddy to use with his boat and shell out a couple grand to put two gear drive units in there.
Ultimately I want it to be reliable and relatively inexpensive (i.e. do it once!)
Thanks in advance for the advice...
BTW I live up the hill from Fresno so I may just bring it in for a brainstorming session with one of the guys at the shop.
junya92toy
You can add a case to the chain one, you can get rid of it and get 2 gear cases. Just go look at the store part with transfer cases and it will kind of explain the options you have.
bigarms23
 i think the gear driven case goes in front of the chain driven one that 4runner your picking up is it black and linked
yoshaleng
Quote"You can add a case to the chain one, you can get rid of it and get 2 gear cases. Just go look at the store part with transfer cases and it will kind of explain the options you have."
X2
I beleive having dual stock cases will slower than a single w/ 4.70.
crawling209
You'll be happier w/ dual cases..
93REDCRAWLER
GreyZuk
Quote from: bigarms23 on January 18, 2011, 07:58:09 PM
Yes it is. :-)
