Bobby Long Beadlocks
Started by swapped89, January 11, 2011, 09:34:23 PM
swapped89
Just got some Bobby Long Beadlocks, with the anti coning ring  :cool: Super stoked.these are going on 15x8s with some old school 37" MTR's... was gonna install them this weekend until i realized i have 2.5" bs rims which I guess means the wheels have been flipped. From what I have read this means that all(most) rims have an, inside-strong bead//outside-weak bead. the outside bead on 3" or more bs rims weaker then the inside bead. So on my 2.5" back spaced black steelies. I have the stronger bead on the outside and weeker on the inside... But for the ideal setup I would need the stronger bead on the inside of the wheel and the weeker on the outside giving more purpose for the DIY beadlock... hope i didnt lose any one there.
Anywho i got my beadlocks and just painted the outer ring. Gonna start lookin for some 3" bs black steelies so i can get these babies rollin :driving:
Inner ring gets welded inside the lip of the outer part of the wheel (that extra ring of metal is the anti coning ring)
The anti coning ring does just what it sais. It keeps the outer ring that compresses the tire between the two rings from coning. making a stronger DIY beadlock. and keeping your bolts straighter and your outer ring stays flat.
outer rings before paint
after paint, I went with the charcoal grey hammered rust "o" leum paint. sorry for the :pokinit: cell phone pics
more to come once i find some 3" bs spaced wheels :D
SAS 89 p/u 3.0 5speed, bobbed, locked, ready to play in the rocks. or wherever the pavement ends :)
http://board.marlincrawler.com/index.php?topic=61345.0
a wise man listens and observes more so than he opens his mouth.. and when he does it is valuable information....   (twistedtoy92)
91 ex-cab
Lost me for a second, but I get it. You want to weld the ring to the weak side of the rim because the ring will then make the weak side stronger, so you will have a rim with both sides strong rather than a rim with a really strong side and still a weak side right?
oh and the paint is gonna look sick on your truck with the black steelies :thumbs:
yoshaleng
How much did you pay for them? Post pictures once you're done, anxious to see the out come.  :popcorn:
swapped89
Quote from: 91 ex-cab on January 11, 2011, 09:42:34 PM
EXACTY RIGHT thanks for summing it up for me. :thumbs: :beerchug:
Quote from: YosHaleng on January 11, 2011, 10:41:25 PM
http://www.longfieldsuperaxles.com/products/15%22-WELD-ON-BEADLOCKS.html
Will post pics when I'm done FO SHO!!  :gap:
Peterbuilt84
A little off topic, but how do you like the rustoleum hammered paint? I've considered using it but have never really heard anything on it.
Those beadlocks are going to look :cool: when there finished, too. As always looks like bobby long made another quality product.
I'd check summit for wheels if you haven't already, you can probably get what your looking for at a decent price.
swapped89
Quote from: Peterbuilt84 on January 12, 2011, 12:20:23 AM
I really like the hammared paint! It works best if you can paint it on a horizontly flat surface. And i would test it out a couple times... To get it to look good you gotta lay down about twice as much as a regular paint. Never got a second coat to work with this stuff. But with some practice you can make it look :boobs: with one coat. :yesnod:
I just found my LesSchwab receipt and typed in the product code on the Allied Wheels website and found that they should be 3 3/4" back spaced so I might be set to jet on the welding this weekend.  :greengrin: (reciept is from replacing a bent wheel a couple months ago) But Im gonna pull a wheel tomorrow after work and measure. My saying they are 2.5" bs was from memory about a year ago when i bought the tires/wheels used.
If they turn out to be 2.5bs I will check out Summit Racing. :thumbs:
wheel product code 5158060
yota4x4sc
:usa: 92 xcab, full width, 39.5 boggers, beadlocks, 60 f arb 5.86s , 60 r spool , duals, 4.7 rear... 3.sl0, bobed , all pro 6 inch leafs f and r :usa:
sweetmeat
I got a set of bobby's beadlocks about 6 years ago. Love em, still rockin
Only pics i got
A&G Motorsports Class 1 #1553 Crew Member
Wrecked4x4.com
yota4x4sc
83 Crawler
they look even better in person!!
swapped89
Quote from: yota4x4sc on January 12, 2011, 09:19:33 AM
pics yet?
Read first post...I just painted the outer rings last night and still have to figure out if my wheels have the right backspacing, befor ei can install them. :thumbs:
thankjs for the pics SWEATMEAT  the new Bobby Long locks dont have the fancy touch to them like the old ones. But I think it will help keep the popo's  :eye: :eye: from catchin a glimpse of what they really are. :crossed:
yota4x4sc
Quote from: swapped89 on January 12, 2011, 10:12:31 AM
i did read.. i aint look at the date
toyotanner
i don't think your wheels are 3 3/4" bs maybe 3
swapped89
Quote from: toyotanner on January 12, 2011, 12:28:14 PM
I dont either thats just what the website said for my product number. Im gonna pull a wheel tonight and measure it for myself. :crossed:
swapped89
WOOHOO! I dont know why I thought the wheels were 2.5" BS. But I just measured and they are the standard 3.75" BS so Im set to jet this weekend. Just gotta go to the sporting goods store and get some airsoft bb's to throw in when I start mounting stuff up. :thumbs:
toyotanner
wow thats crazy you must rub spring like its going out of style i have 2.5" bs and i touch spring here and there
swapped89
do you have wheel spacers? My tires never rub the springs.
NCK4L
#17
Quote from: toyotanner on January 13, 2011, 12:16:02 AM
the less backspacing you have the more your tire sticks out of the fenders. the more you have like a stock 4 inch BS thats when your tire would be rubbing springs. less is better , i think a 2.5 - 3 inch BS would be ideal with a 1.5 spacer if youre runnin 37's or bigger.
edit : forgot with less BS the more your tire swings so i see how you would rub with the 2.5 with out spacers
83 Crawler
superyota
good info in the post.  can someone please clarify for me what you mean when you say a 2.5bs wheel has a week side on the inside vs. a 3 or 3.5bs?  I'm getting ready to do this same set up on my 2.5bs wheels.  i really don't want to go with less bs.  is the steel actually weaker, or are you talking about the bean portion where the tire seats not being able to hold the tire on, on the inside of of the 2.5bs?  hope i make sense.
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
swapped89
#20
2.5" bs spaced wheels have the weeker bead on the inside of the rim.
3" or more have the week bead on the outside of the rim.
Beadlocks on a 2.5" bs wheel still leaves you with the week week bead on the inside of the tire. Its just not the best way to go about having beadlocks. also with the 2.5"bs wheel people have a HELL of a time getting the tire over the outside of the rim. I have read about tire companies breaking machines just trying to get the bead over the outside of a 2.5"bs wheel (EDIT: after the ring is welded on) . Do some research and you'll see what i mean.
jackson58
I have 2.5 backspaced rims that the safety bead is on the inside and have never had any sign of a problem mounting tires. Rubbing springs with these wheels with no wheel spacer is also not going to happen.
Dirt is for wheelin not for wearin you filthy hippie!
91 ex-cab
Quote from: jackson58 on January 13, 2011, 07:50:35 PM
I think he might of been talking about once the ring is welded on.
1980yota
I run 4" bs rims with 35" tires and 1.5" spacers with no rubbing issues. I think I will have to change wheels when I bump up the tire size though.
Ready to see some finished pics! I was thinking about going this route with the new wheel tire combo.....
swapped89
http://www.pirate4x4.com/forum/showthread.php?p=5028692  (A little about 2.5" bs wheels)
and post #4 in that thread has another link.
:thumbs: just one of the many things I read tryin to figure it out.
I think Im goin snow wheelin tomorrow night, but I will more than likely have pics by saturday night  :D
swapped89
Picked up my "tire balancers" today during lunch, got two bags. :gap:
will take 980 of them to make 7ounces worth. Thats how much Im gonna start out with in each tire.
toyotanner
are you going to count them out? hahaha
and i run a 2.5" bs wheel so i dont have to run wheel spacers and can still steer my pig
swapped89
Quote from: toyotanner on January 14, 2011, 12:53:03 PM
yes Im gonna count them one by one...  :shake:  Anyways I had to work all weekend so no  beadlocks till next weekend  :hammerhead:
swapped89
Well i got some work done on the beadlocks this weekend. Things have been pretty crazy with me brerakin up with my girl of 5 years so im havin a hard time gettin these babies done but they are almost done. Hopefully tonight i will have a couple of them put together. :beerchug:
cleaned the paint off the rim
filled in valve stem hole so i can move it for easier access
ring centered and tacked on
layin beads
teaser pic
twistedtoy92
Lookin good! I want to do this to my wheels this spring..... :beerchug:
