Bobby Long Beadlocks
Started by swapped89, January 11, 2011, 09:34:23 PM
81yotalove
those look awesome. maybe one day i'll have some lol.
81 swb 22re 35's
yota4x4sc
whats that inner hoop thing for? strength ? how do u get the nuts on the back of the bolts? looks like a really tight fit
:usa: 92 xcab, full width, 39.5 boggers, beadlocks, 60 f arb 5.86s , 60 r spool , duals, 4.7 rear... 3.sl0, bobed , all pro 6 inch leafs f and r :usa:
yoshaleng
twistedtoy92
Quote from: yota4x4sc on January 24, 2011, 07:09:31 PM
Anticoning ring- exactly what it does
I loved my LF beadlocks.  High quality stuff and came with quality hardware.  Too bad some scumsucker decided they wanted them more than I did.  Oh well, having my 38's stolen started me down the road to 44" stupidity I'm on today. :talkingn:
swapped89
last night my buddy stopped by and helped me put all the tires over the wheels. and got one of the tires completed blown up and sittin on truck. If it still has air in it when i get home from work today ima finish up the rest of them tonight :)
After i ground the weld smooth i painted the inner rings. Then after we had the tires set over the rims and ready to bolt down I put a bead of automotive sealant inbetween the tire and the inner ring. :thumbs:
added 9oz of .20g air soft bb's
:beerchug: :beerchug: :beerchug: :gap:
SAS 89 p/u 3.0 5speed, bobbed, locked, ready to play in the rocks. or wherever the pavement ends :)
http://board.marlincrawler.com/index.php?topic=61345.0
a wise man listens and observes more so than he opens his mouth.. and when he does it is valuable information....   (twistedtoy92)
superyota
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
91 ex-cab
Those are some nice red x's.
Fix them pictures I wanna see these things :beerchug:
LD
Makes me want to make some locks for my rig now. How do they do on the street?
The best place to find a helping hand is at the end of your arm.
91 ex-cab
Must have just been my work computer, cause they work now.
They look good :thumbs:
swapped89
Quote from: LD on January 27, 2011, 05:35:02 PM
Workin on the other three right now.  :_order: as stated above
LD
 :hammerhead:  sorry about that. Let us know how they drive when your done
swapped89
Haha no prob. Got the last three bolted up and two of them blown up and on the truck. But the inner bead on the last tire has a lil nick in it. Could'nt build enough pressure to seat the bead. So my buddy is akin it to his old workplace. A custom 4x4 shop to try and seat it. That don't work I'm fillin my 10lb cO2 tank today at work and I'm sure I can seat it with that. I woulda used it last night in the first place but I ran outta co2. Tank was more then half empty after fillin my tires up 3 times from 7psi to 25psi. And two other rigs tires.
LD
You don't want to use some starter fluid? That's always fun
jackson58
Would you mind getting a measurement on how wide the anti-coning ring is?
Dirt is for wheelin not for wearin you filthy hippie!
swapped89
Quote from: jackson58 on February 10, 2011, 04:18:55 PM
Sorry it took such a loooong time to reply dont have a computer any more.
the ring is 3/4" wide.
lownlinked85
Hey how do you like the bobby longfield beadlocks? Would you recommend them to a daily driver? Did you ever balance then with wheel weights. let me know Also how hard was it to center the ring and do all the work I want to do a diy kit but want to know if its worth the hassle or just get allieds. :dunno:
Low locked and ready to rock
swapped89
Quote from: UnderConstructionProject 85 on March 08, 2011, 02:52:06 PM
I love them. If u read thru the thread i put air soft bb's in the tires for balancing, works great. I daily drive this thang everyday.
lownlinked85
so those air soft bb's is all you need to balance the tires I tried reading the other bb balancing thread but got confused so you don't have wheel weights thats good now do you know if the these beadlocks are compatable with other rings in other words can you take another 24 bolt ring and slap on there because the LF ring looks lame
jackson58
Quote from: swapped89 on March 08, 2011, 01:21:00 PM
Not a problem, thanks
twistedtoy92
Quote from: swapped89 on March 08, 2011, 03:25:27 PM
Thats pretty good right there :yupyup:
swapped89
Quote from: UnderConstructionProject 85 on March 08, 2011, 06:23:04 PM
i dont see why not if the bolt pattern is the same, but yer just gonna be adding more wieght and probly make it harder to balance.
Quote from: twistedtoy92 on March 08, 2011, 07:24:18 PM
:beerchug:
swapped89
not a tight fit at all. It all went together real easy.
yotatough
the hoop is an anti coning ring, it keeps the outer ring from bending when the bolts are torqued down
toyota castine
Lookin good, bobby long has some realy good stuff.
swapped89
crawlerbubba
GOT ROCKS?
