Rolled 85 toyota 4runner ........ouch
Started by ezthere, January 09, 2005, 03:27:14 PM
Mike D
Looks nice  :biggthumpup:  Bet you can't wait to have it on the trail :driving:
ezthere
Damn right. My only issue is the fuel system.Carb  :_oops:    Not very good for steep grades..I was thinking about a throttle body unit but not sure how much and ease of installation... :dunno:
i have a set of 4.88's.That have not been installed. I guess I should wait untill I get the lockers...
Chuck
TrackVino
stone4x4
where do the shifters come out in the floor
doing the same tranny to mine aa th350 to a yota tcase mc08 yota tcase
so i'll have a th350 with dual yota cases
i'm going to run a 4.3 V6
GOD MADE DIRT AND DIRT DON'T HURT
The AA adapter will put the crawlerbox shifter in the stock spot as the transfercase did when it had the origional engine.
stone4x4
ezthere
Trash is right...
However if your running a 350TH. Or a 700r4 in my case..Your tranny shifter and Tbox shifter will want to share space.Not possible with out mods to the Tbox shifter. I had to weld an "S" type shifter extension.I cut a square hole on the left side. of the tranny tunnel just below the B&M mega shifter. The Tbox shifter now sits just below my right knee.
My real problem is tranny shifter cables. The cable has to be snaked around in a long "S" shape.The trouble is the angle of the bends..That's using the 5ft shifter cable..I put 20k miles on the cable and its SHOT.
http://store.summitracing.com/default.asp?target=esearch.asp&N=110&Ntk=KeywordSearch&Ntt=B%26M+cable
I will try the heavy duty cable this time.Its longer and will give me the extra length..For the bends..
Chuck
Chuck
