subaru wrx
Started by Goldrush, December 22, 2010, 09:33:56 AM
Goldrush
ok. my friend has a wrx that is awd and he wants to know how it works.. i know little of it myself, but im pretty sure not all four wheels are locked all the time right?? i mean you wouldnt be able to turn the thing, so i was wondering if anyone can give me a good simple answer to tell him. thanks!   :beer:
p.s. is it like a quadra-trac system??
Nimyad
Its a fluid design, most of the power is sent to the tire with the most traction, but it's an always changing thing
GNasty 82
From what I understand, the front and rear diffs may be LSD.  The thing is that there is a middle diff (think xfer case in our trucks) that is also something like an LSD to send power to the front and rear.  Yeah, I know is a pretty crude description, but it's all that I know about them.
82 Toyota SR5 Pickup
  Marlin Dual Ultimate
  Front 5.29 LC HP Elocker
  Rear 5.29 Grizzly Locker
  BFG 37" KM2s
  Custom rear frame and flatbed
  Propane Powered.
Build Thread:
http://board.marlincrawler.com/index.php?topic=64521.0
Quote from: Toymin8r on July 19, 2010, 02:18:05 PM
"The two enemies of the people are criminals and government, so let us tie the second down with the chains of the Constitution so the second will not become the legalized version of the first."-Thomas Jefferson
Peterbuilt84
Did you search on google? Lots of results, here is one that I found.
http://www.autoworld.com/news/Subaru/Subaru_All-Wheel.htm
Goldrush
ya i googled it and couldnt find anything, but thanks. so it varies on how many tires are pushing the vehicle?
Peterbuilt84
Basically, it is always in 4wd. The center diff acts as a limited slip transferring power away from the slipping tires. Under normal conditions it is evenly distributed front and rear, although I have heard it is 40/60 front to rear also (don't know if this is true).
I'm assuming your friend has a manual transmission? If it's an auto then it's probably different.
Edit: here's what I searched
http://www.google.com/search?hl=en&source=hp&biw=1259&bih=574&q=subaru+all+wheel+drive&aq=0&aqi=g10&aql=&oq=subaru+all+&gs_rfai=
Goldrush
ya its a manual. thanks. i think i get it now.
bleakhorizon
its called a viscous coupling.....
and the newer cars use the brakes on the wheels that "slip" to send the power to the wheels that "grip" (sorta like the oldschool wheelers may have talked about applying there ebrake a little to help the open or limited slip diffs)   but differant lol
WRX may have LS diffs however....
Those are some huge welds!
Tillamook, OR
88_Pathy
The rear diff is LSD the front is open.  A WRX is a rear bias set up with around 60% of the power directed to the rear.  The Transmission has an integrated "t-case" to power the front and rear tires.
4LoRunner
anyone call Ken Block about this yet :yupyup:
Sas'd '86 4Runner, 22RE-T, 4.88s, Dual Stock T-Cases, Locked F/R, 35" MTR's.
http://board.marlincrawler.com/index.php?topic=55751.0
Peterbuilt84
ken block drives a ford now  :thumbdown:
4LoRunner
yea which blows!!!! guess subaru wasnt paying him enough
Goldrush
Tofudude
the fiesta he drives looks way better than the new STI
4LoRunner
i liked the first sti for gymkahana 1 way better but if they were to give me his gymkahana 2 sti id drive it anyday
you kno ford had to do so much to that fiesta just to make it comparable to a stock sti let alone his past upgraded sti's
81_yota
when it come to the subaru manuals its awd all time autos are diff autos are meanly front but with hydro in trans tells how much to go to rear manuals if u jack all 4 up in air spun one in front rear of op side would spin to true on manuals it is a 40/60 split brakes have nothing to do with it subarus are from another world they have mastered the awd system
