Found a screaming deal, + I got a rear axle guestion.
Started by 86yota, January 05, 2005, 03:42:50 PM
86yota
And now a short story.  Went in to a local junkyard today to look for a third member to rebuild.  I asked if they had any four wheel drive Toyota parts, mostly axle parts.  He said yea I got two of them over there.  They had an 89 4-cyl rear end and a 80-83 front end, complete except for 1 locking hub.  I asked how much for the thirds.  He said, well I dont want to sell just the thirds.  I said I'd give him $40 each and I would pull them.  He said he would be right back and he would see what kind of deal he could make me.  He went inside for about 10 minutes then came back out and said "I'll sell you both complete axles for $100, $50 each."  Done deal.  So now I got two axles for $107.25!!!
The Question I have is about the 89 rear end.  One of the lower bolts that holds the third member in is unusually long.  Is this typical of 89 and up rear ends?  Is this pumpkin the same as the 79-88 pumpkins I usually deal with?  I was going to put this in a front axle so what needs to be done to do this?  Just put a longer stud in the front housing?  Any info apreciated.
Willy Mammoth
I am guessing, but is it maybe a V6 rear? I think they will work, but you will need to clearance the housing to install the third member and of course change the stud. I would wait to see what others have to say before taking my opinion to hart.
Good luck
Willy Mammoth
That is a screaming deal by the way. The yards around here get $300.00 for rear and $500.00 for a front.
86yota
Im almost positive its not a V-6.  I had a V-6 out of a 92 runner before and it had more ribs on the case.  This one has the same number of ribs as the front 83 third.  I dont remember that V-6 one having that one long bolt though,  I ran the V-6 in a front axle also.  I think I would have noticed that putting it in.
Willy Mammoth
Post up a picture so we can see what it looks like.
Some of the 3rd gen trucks have a thicker 3rd housing and use a rather long stud to retain the 3rd.  My 94 was like that.
derek
one of the studs is longer.
there is a thick section on the third that the stud goes through.
i think it is just for alignment purposes so you dont guess it one stud off.
the normal length studs are long enough to go through it, just not as much thread sticks through.
derek
jr9162
Is the thick section of the housing where the long stud is located at notched? Wondering if the housing was set up for an electic locker but one wasn't installed at the factory. Or the electric locker was R&R with an open diff at a later time for some reason?
I'm a member of P.E.T.A.
People Eating Tasty Animals
There's no nookie like chinookie
No butts like halibuts
Fish are not our friends, they're food.
Eat more moose - 10,000 wolves can't be wrong
Calling an illegal alien an "undocumented immigrant" is like calling a drug dealer an "unlicensed Pharmacist".
derek
its not a really thick section. it just like a 1/8" thicker around one stud.
its normal on all the third members.
derek
derek
if i had my camera here at work i would go take a pic of it.
derek
You have the later housing I can pretty much guarantee it.
derek
just looked at my 82 yota daily driver and it has the 1 thick spot where the longer stud goes.
its one of the bottom drivers side stud holes on the third.
derek
If the flange is about 5/16" thick in most places its an earlier housing.  If its about 3/8" its a later model.
derek
thought all the 4cy third housings were the same?
every one i have set up gears on have been identical.
derek
When I get home Ill take a side by side pic for ya.  I didnt think there was any difference either till I started stripping the 94.  I did notice that the hi-pinion diff has the same thickness flange.
derek
hhmmm thats odd.
seems that would mess up the axle alignment by 1/16 of an inch if you put either one in the older/newer housings. :headscratch:
dont know if 1/16 would be enough to cause a problem.
they all use the same gear set? hell even the v-6 can use the 4cyl gears with a ring gear spacer.
you can fit the v-6 gears in the 4cyl third by mix matching pinion bearings/races.
derek
derek
i guess 1/16 isnt enough of a difference to cause a problem over the whole span of the axle though.
derek
derek
but anyways the long stud is supposed to be there. :laugh:
and you shouldnt need to put a different stud in the front to bolt the third in. :thumbs:
derek
I thought that toyota axles had 2 longer studs, one on top and one on bottom.  I think the third also had the thicker part for those 2 studs also.
86yota
Here is a little more info on the axle.  The long stud is located on the bottom side near the pinion and it is not just slightly longer, it is about 2 1/2 inches long.  I was told it was out of an 89 and had 3.07 gears by the guy at the wrecking yard.  3.07?  I just thought he didnt know wtf he was talking about.  As I looked at the third closer I noticed that the bulge on the outside of the third that is around the pinion area is quite a bit larger than the other toyota axles I have?  Large pinion? 3.07gears?  Maybe?  I will crack it open this weekend and see what gears it really has.  The axle housing has wider spring perches.  Same distance apart, but its like they are made for a 2 1/2 spring or something?  I dont have a digi camra or I would post a pic.  Has any one seen anything like this?
The real late model axles have a wider perch.  Its actually around 3" wide.  The dude must have been smoking some good stuff as ive never heard of 3.07's in a yota.
bluetoy84
WT is correct. The later model 3rd's have a thicker flange than the early models. I think they changed around 89'. Don't worry though, it will work in your housing with no problems. Slap it in there and give er' hell !! :thumbs:
Also, I've never heard of 3.07's :dunno:
