Author Topic: 94 22re idleing up and down  (Read 14420 times)
red450r
  • Turtle Points: 3
  • Member since Nov '10
« on: Nov 25, 2010, 11:48:46 AM »
my truck idles up and down when you push the brakes or turn on the a/c, ive cleaned the throttle body, no difference, any ideas?
  • Turtle Points: 1128
  • Male Posts: 9,757
  • Member since Oct '04
Re: 94 22re idleing up and down
« Reply #1 on: Nov 25, 2010, 12:15:17 PM »
Vacuum leak?  Don't have a manual nearby, and I could be remembering wrong, but it seems like that's what's happening when you put a heavy load on.  This is a great site, but this isn't a toy specific problem, and I'd bet dollars to donuts (you could send me either if I'm right :gap: ) that a quick google search will find your answer  ;)
DKONG
  • Member since Aug '10
« Reply #2 on: Nov 25, 2010, 01:01:32 PM »
How high is your idle? On my 85 22re i was having same problem, adjusted idle adjusting screw to about 750 rpm warm and havent had a problem since. I hope this helps you out.
red450r [OP]
  • Turtle Points: 3
« Reply #3 on: Nov 25, 2010, 01:25:36 PM »
it idles pretty high, truck doesnt have an tach so im not positive, i have looked for vaccum leaks and found none
DKONG
« Reply #4 on: Nov 25, 2010, 01:31:52 PM »
I honestly think thats the problem, its worth a try.
yota4x4sc
  • Turtle Points: 28
  • Male Posts: 596
  • Member since Oct '10
  • Santa Cruz, CA
    • My YOTA Pics (click here)
« Reply #5 on: Nov 25, 2010, 03:59:27 PM »
heres factory service man...
but spray carb cleaner all over everythin and see if it idels up more over anythin.and theres ur leak
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
:usa: 92 xcab, full width, 39.5 boggers, beadlocks, 60 f arb 5.86s , 60 r spool , duals, 4.7 rear... 3.sl0, bobed , all pro 6 inch leafs f and r :usa:
twistedtoy92
  • Turtle Points: -255
  • Male Posts: 3,781
  • Member since Dec '06
  • NFM Customs
« Reply #6 on: Nov 25, 2010, 04:06:25 PM »
IAC! I had the same prob, they carbon up and stick open and allow too much "un-metered" air past the throttle plate. I swapped a new Idle Air Control Valve in and BAM! No more revving up and down with my foot on the brake pedal. I also dont have A/C so I bet thats what you've got going on. As long as your Brake Booster supply line doesnt have a leak then I almost guarantee its your IAC! Just my past experience :beerchug:
Happy Thanksgiving!
  • Male Posts: 9,757
« Reply #7 on: Nov 29, 2010, 08:25:28 PM »
Any updates?
red450r [OP]
  • Turtle Points: 3
« Reply #8 on: Nov 30, 2010, 12:45:35 PM »
havent had a chance to touch it, been working seven days a week
red450r [OP]
  • Turtle Points: 3
« Reply #9 on: Nov 30, 2010, 12:57:22 PM »
where did you pick up your new iac and how much it hit you for
Happy Thanksgiving!
SloCrawler
  • Turtle Points: -116
  • Male Posts: 1,333
  • Member since Mar '08
    • http://board.marlincrawler.com/index.php?topic=60800.msg856812#msg856812
« Reply #10 on: Nov 30, 2010, 02:15:39 PM »
I have the same problem on my 89, i thought idle was just to low, ill have to check into IAC
twistedtoy92
  • Male Posts: 3,781
  • NFM Customs
« Reply #11 on: Nov 30, 2010, 06:21:34 PM »
I got mine from napa I believe.... and it was $180.... Toyota is even more but I think I would have bought it from Toyota if I had to do it again......
santa cruz crawler
  • Turtle Points: -7
  • Male Posts: 682
  • Get Some
« Reply #12 on: Nov 30, 2010, 07:15:53 PM »
if your truck is cutting rpms when you are on the breaks,check your alt voltage and turn a bunch of stuff on in your truck,then turn your lights on and see if the lights dim ....idk its what id start with.... good luck
also make sure all your plugs under the hood are good and tight .wiggle all the wires,some times giving a toyota  a good ass kickin helps !!
twistedtoy92
  • Male Posts: 3,781
  • NFM Customs
« Reply #13 on: Dec 01, 2010, 08:43:46 PM »
the reason it will surge is because you are letting un-metered air into the intake and when you apply the brakes it requires vacuum for the booster, adds more fuel then realizes this is too much fuel, cuts injectors then levels out again... It took me ALONG time to figure this one out. dont believe me? take your IAC off and seal the TB up with a block off plate in place of the IAC. Bet it wont surge anymore! They are activated by coolant temp to open and close for quicker warm up. When they stick then you get this surging up to 1400 RPM or so then a rapid drop in RPM's and the cycle continues as long as you are on the brake pedal!
PARTSDEV
  • Member since Jun '10
« Reply #14 on: Apr 27, 2011, 04:22:23 PM »
had the same thing on my truck,just adjust your base idle to specs with all acessories off,than turn on ac-fan on high this should kick up idle.check to see if tach is reading 950 rpms.if not adjust the turn knob/screw on that vacuume thing on intake.forgot what toyota calls it but we all have em if we have ac.ok so turning the knob shuold raise and lower rpms.once set-drive and see. let us know if this works!!!
toysfreak
  • Turtle Points: 227
  • Male Posts: 632
  • Member since Sep '03
  • I Love My Marlin Crawler!
« Reply #15 on: Jul 17, 2011, 08:22:25 PM »
Everytime when my coollant is low. It will surge as u state.  On another 22re I had it was the tps sensor on the throttle body. Ck coolant temp and wires to the plug too. My 02.   Tony
95 4 runner. 4 cyl dual ultimate w. R150.  V6 rear w spool.  New Chevy springs on 12" extended frame.      Front.  SAS w chromoly shafts.  And spartan    In frazier park ca 93225
Last post Jan 18, 2006, 04:53:44 PM
by Skinny_Pedal
Last post Mar 03, 2007, 04:06:19 PM
by Tallchevy
Last post Mar 26, 2007, 01:36:56 PM
by Cheesemaker
Last post Apr 22, 2010, 02:11:27 PM
by greenseaman
Last post Oct 20, 2010, 07:18:55 PM
by 954toy
