Newbie here! Looking to build up my 1985 Toyota Pickup
Started by codyps85, November 21, 2010, 04:05:59 PM
codyps85
Hey gang,
My daily driver is a 1985 Toyota Pickup named Betty. I drive her 60 miles per day and is reliable as hell. I want to build a rig that is a good daily driver, but can tear up the trails on the weekends.
The majority of the time Betty (my 1985 Toyota Pickup) will be crawling, but enjoy the fast stuff too. Here is a list of the modifications that I currently have:
Body: 1985 Toyota Pickup Long Bed, Regular Cab
Engine: 22R rebuilt about 80k miles ago and Rebuilt carb
Front suspension: Allpro 4 in. long travel springs, Datin fab spring hangers, Allpro shackles, Allpro shock hoops, 14 inch Rancho 5000s
Rear suspension: Trail gear 3in. long travel springs, Long travel shackles and spring hangers, 12 inch Bilstien 5100s
Drivetrain/Steering: Allpro cross over steering kit,92 Toyota truck steering box, Custom square front drive shaft with double cv, Custom 1 piece rear driveshaft with double CV, 4:88 gears, Aussie rear locker, open front
Other: 35/12.50/15 Mickey Thompson MTs, Custom offset black steel wheels, Fabtech spare tie carrier, Smitty built rear bumper, 10k HID headlights, cd/ipod/am/fm stereo, a/c, and heat
Right now, I do not have armor, front bumper, winch, front lockers, or any t-case modifications. I believe my next upgrade will be 4.7s. Would you guys agree?
'85 Toyota PU, 22R, 4.70 t-case gears, 4.88s, Aussie Rear Lockers, Spartan Front Lockers, Dirty Thirties, 4" All Pro Springs and shackles front and rear, 37" Creepy Crawlers on beadlocks, full cage, no bed, A/C, and CD
boomtacoma01
I would start with a good sturdy set of sliders to prevent any rocker damage since the truck is your DD. But yes 4.7s would be a nice upgrade. Looks like you have a pretty nice setup to begin with
85 Ext Cab 22RE, 3 Linked front D60, 14B, Full Hydro and 40s
IG @boomtacoma01
codyps85
Thanks for the suggestion. I know that I need sliders. It's definitely on the list. I've been lucky to not have any significant body damage yet but it's bound to happen. Ideally, I would like to do the sliders and the tcase, but you now how it goes... gotta start saving my chips.
bigarms23
NCK4L
if you can make sliders do that its cheap . then find a  used 4.7 case with marlin gears usually cheaper than buildin your own. make sure you put selectable lockers in it if you are using it as a dd .
Goldrush
if u want to go fast and go slow, you can do dual cases. you have more options that way, and yes sliders and bumpers would be good to start with.
punchyyoter85
sliders and nitrous! lol jk i would say sliders and bumpers, then do 4.7s thats what i plan on doing to my 85 in that order, but hey ur truck just my .02
SCyotacrawler420
i like the nitrous idea. speed wheelin? haha. buy trail gear sliders, there dom tubing an super cheap/easy to put together. then from there on maybe like everyone else said do bumpers, then 4.7 to save clutch, then do a front locker an maybe hydro assist
ajordan1975
Jokeass-Wheelers
ARB!!! bob the bed custom rock sliders since dd possible interrior cage? depends on how hard you romp it
11 Jokeass-wheelers 7
1985 Toyota 4runner 22re 4x4 5:29 38in tsl's
IF IT LOOKS LIKE A PIG SMELLS LIKE A PIG IT MIGHT BE A PIG
4.7's and a front locker and it will be unstoppable.
Jokeass-Wheelers
codyps85
Guys,
Thanks for the great info. Here is where I'm at so far -
Purchased and Received:
Marlin inner axle seals and a front knuckle rebuild kit
Diff armor front and rear
Front axle truss
Purchased and awaiting arrival:
4.7s
Sliders
Not Purchased, but saving up for:
U bolt flip kit
Spartan front locker
Better than stock birf
So let me know what you guys think. I'll get some pictures up once i get everything installed.
ajordan1975
codyps85
I completely agree with you. I just don't have the money for 30 spline birfs, so i will spend the $100 and buy the better than stock 27 spline birfs and keep my stocks as spares.
codyps85
What up gang? Since my last post I have purchased and installed TG 4.70 low range reduction gears for my transfer case and thanks to my buddies, Matt and Hartley, I've installed them. I've also purchased a Smittybilt 8000 lb winch, TG rock sliders, Spartan front lockers, two sets of ubolt flip kits, front and rear diff armor, and I'm not going through the process of installing them.
First to go on will be the rock sliders, since they are the easiest. Then the rear ubolt flip kit - since my rear end is already built and locked.
After those two projects, I will build my front bumper (which I've already designed) so that I can mount up my winch.
And finally build my front end... I have to grind off the steering stabilizer mounts to weld on my front axle gusset, replace, my birfs with TG dirty thirty birfs, put in my spartan lockers, Marlin axle seals and front axle rebuild kit, and then put in the ubolt flip kits.
I'll keep you guys posted. It may take a while since I have to coordinate time to use my buddies garage, but my target is to have everything installed and rock ready by KOH 2011 in Feb.
codyps85
Quote from: codyps85 on January 12, 2011, 06:01:42 PM
I forgot to tell you what a difference this makes. This was the smartest decision that I could've made. More torque, lower range allows me to be more deliberate with my lines. I LOVE THEM.
yoshaleng
Like everyone else said, lockers, gears, t-case gears, and armor will do you alot of justice.
codyps85
Yes sir! Before long I will be locked front and rear. Tcase gears are in and armor will be welded on soon!
I CAN'T WAIT :beerchug:
See you guys at KOH 2011
yotaneck13
Nice truck lookin good my buddy has an 85 gonna mention this thread to him bc he needs to get something done with his truck or its gonna go down hi fast
codyps85
Sounds good man. The more Yota Crawlers the better.
My buddy beats on his '85 every weekend and that thing is still going strong, so I'm just seeing what works for him and then modifying it for my application.
yotaneck13
im getn ready to tear into my 90 gonna sas  tires of the no flex ifs lol
codyps85
yotaneck13
soon as i get all the to yota parts cleaned up ad can actually get it in the garage
