Steering??? push and pull box to forward swing... think it would hold up???
Started by Redbeard1, November 11, 2010, 06:35:29 AM
Redbeard1
Just wondering has any one used a Toyota push/pull (stock solid axle box) steering box for forward swing cross over steering? If you pulled the box off of it's bracket turned it 90* counter clock wise moved it back about 4-6" on the frame and mounted it I know it would work in theroy but would the box hold up?  I have seen forward swing boxes on Toyota trucks before but they have been off of a LC or a Scout and they work well. I just dont know if the push/pull bo would be strong enough to handle the abuse.  I know that the pitman arm from a IFS box will fit on the SA box both are 30 mm 48 spline shafts.
Any thoughts???
If you dont stand behind our Troops... you can stand infront of them...
Project Pete==> http://board.marlincrawler.com/index.php?topic=43370.0
85 Toy: Built 22re, locked F, spooled R, 5.29's, R151F, MCO7 duals, Sky x-member 37 MT/R's on jack stands
__________________________________________
||____________||____________||___TOYOTA ___||
||____________||____________||_____________||
RIP Bobby Long
H8PVMNT
It could work but I think it is just WAY easier to swap in an IFS steering box.  They are also cheap and available...
– Steve McQueen
zippo
If you see it, its for sale.
Phazertwo
92 xtra cab, with some stuff...
Quote from: yotabj on October 30, 2006, 10:01:02 AM...why buy when you can build?
TacoRunner
Quote from: redpim1 on November 11, 2010, 06:35:29 AM
Any thoughts???
Only if you use a non-power steering version. Which of course means, you have no power steering. Which of course means this is bad idea.
www.4WHEELUNDERGROUND.com
[email protected]
Redbeard1
Yeah after looking at the box again I am with zippo.  Just one of those bored out of my mind brain storming sessions i have from time to time.
RIP Bobby Long
