Which size leaf spring for F&R??? Thanks
Started by lone walker, November 08, 2010, 10:14:42 AM
lone walker
On a first gen yota. I plan to do a 5 inch leaf lift on 35 and 5.29 gear.
What would you recommend?
-all around 5 inch leaf spring?
-4 inch front and 5 inch rear?
What and why would be helpful. Thanks
Going, going, gone
87hillbillyoter
4 inch. or 3 in with trimming. also, there are tons of topics on this covered, please search in the future
1987 SAS'ed toyota 4x4 pickup 22re swap
build up- http://board.marlincrawler.com/index.php?topic=75111.0
IronClad
contact national spring and getchu some o dem 18 " lift springs that are in the shape of a V imo
Annihilation  Fabrication
Do you need a Hammer?
Sparkplug
superyota
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
lone walker
Thanks for the help.
I tried searching but did to answer my question.
I wanted mc f/r leafs but em are no longer avail. so I'mma change route to allpro. I did some reading but did not specify if it applies to truck (mainly regarding runners). Do I have to adjust for the weight differences just like runners with heavier rear end such as hardtop, glass, etc. such as using 4 inch leaf for the front and 5 inch leaf for the rear, does this apply to first gen p/u also?
Spoke to some local owners and a few of the stated that they much prefer using all around 5 inch leaf then having them off set.
What is best from you all experts besides using ruf and f150s.
Thanks for any input.
Going, going, gone
86bobbedtoy
man go RUF and F150s.
they flex just as good if not better than others out there.
put that money to better use
greg_k113
H8PVMNT
RUF and chevies or f-150s or you are just throwing your $$ down the toilet...  Keep you money in your drivetrain if you want your truck to wax! :)
– Steve McQueen
86bobbedtoy
           if you need help on what f150s
        or what RUF and how to build them,
                    just let us know!
Quote from: v5e_nsx on November 15, 2010, 06:28:16 PM
NO you don't need to run a different size spring up front,  thats only for 4runners.  UNLESS you have like a utility bed that weighs a LOT
If I was you I'd run the AllPro 4 inch springs in the front and F150's in the rear using the spring hangers from Marlin or AllPro.
for the record, i have 5 inch AllPro springs upfront and F150's out back with and extra leaf to level it out.
F150's give a toy pickup 4 inches of lift
81yotalove
coyote with your f 150's are you using the stock shackle hanger location? it seems that your using short side forward which is what im doing and your shackle hanger doesnt seem moved back. mine is a short bed like yours and the shackle hanger cant be moved more than an inch or so back if need be. and iwould like to just not mess with it. thanks in advance.
81 swb 22re 35's
bigarms23
nothing wrong with 4inch allpros all around
lone walker
thanks for all the imput guys. you're all great helpers!!
Going, going, gone
Lowspot
Running waggys up front and F150s the rear and the front mount moved forward 9 inches and the springs turned around it moves the axle back about 7 inches from stock on an 86 std cab short bed
