89 X-tra cab W/22RE build
Started by silence007, October 05, 2010, 06:30:57 PM
P-DiseToy24
No need to cut just move the axle forward...
Thomas P
Quote from: P-DiseToy24 on October 09, 2010, 04:14:35 PM
yup, since hes got the 5" kit its def gonna be high, im thinking rufs mixed with the new lifted springs to push things forward & lower it slightly and it wont need trimming on 36's
'14 Camry SE
SCX10 Honcho on roids!
silence007
Headed to redding, I think I am getting my second T-case for a hundred bucks, maybe less.
A FRIEND WILL TELL YOU HE WILL BAIL YOU OUT OF JAIL, A TRUE FRIEND WILL BE SITTING NEXT TO LAUGHING WHEN IT DOESN\'T HAPPEN.
silence007
Quote from: silence007 on October 10, 2010, 08:54:45 AM
I got five speed trany with T-case for a hundred bucks, but no shifters, I was wondering though, I was in such a hurry, does it matter if it was from a 3.0?  I didn't ask the engine size, two different mounting positions with four bolts a piece.
Thomas P
'14 Camry SE
silence007
did you see the pics I put on facebook?  I can't seem to figure out how to put pics on here.
Thomas P
'14 Camry SE
Dingman.
They make an adapter so you can run that case but i would just get a top shift gear driven one to make your dual setup
silence007
Quote from: Dingman. on October 10, 2010, 09:20:10 PM
That is what I plan on doing,  I should have caught it before I bought it, I will just rebuild and sell, unless you can use it for parts for yours. If you know someone else I will let it go for the same hundo I spent.
yota4x4sc
 o that sucks..trash the 3.0 t case, chain driven,..the trans is alright but like bro said u need to  buy the adaptor just to run the 4cyc gear drive case/cases.. a lot more money overall if u want to use any of ur new purchase. i have that 3.0 stuff since thats wat my truck came stock with..to make sure its a chain driven t case count the bolts on the back of tail shaft part..there will be 5 bolts if its chain, 7 bolts if its a gear driven case.  :drooling:
silence007
Quote from: yota4x4sc on October 11, 2010, 12:44:56 PM
Thanks, the guy doing my swap said he might have an extra one, maybe waiting for a family members ride, but yeah I'm not using it.  Only a hundred bucks.
Dingman.
Got the front axle completely rebuilt tonight.    Didn't get all the parts yet, only got half of them.   Still waiting on hangars, shackles, springs, shock hoops, brake lines and some other misc stuff.  Should be seeing some better progress soon.    I'll post pics of the axle in a few since I'm documenting this whole thing
Dingman.
yota4x4sc
Thomas P
Brought the torches home tonight, should get the frame tubes in tomorrow, and maybe make a sleeve for the frame to move the box forward
'14 Camry SE
silence007
I got the Iroks today, I think the 36's will suffice for my first toy, doesn't even count as my build because I don't know how to weld yet, Next one will be my build.  A bit delayed.  was told 3-5 business days, today is day 10 for business days, yes that means two weeks.  Still all parts not in.
Thomas P
did you find out anything on those shackles and jam nuts???
'14 Camry SE
silence007
Quote from: Thomas P on October 15, 2010, 10:44:57 PM
No, too much work and when on phone on hold for too long.  I can try to email them, probably still won't get through until monday.  For rear I am thinking the mounts and shackle mounts and make those shackles like you were talking about.  Then I won't spend alot of money and make new ones if I don't like the heighth.
silence007
I think the rest is in the mail, hopefully get her finished this weekend and get some pics up, if I don't remember to ask Thomas or Mike can someone tell me how to post pics on here, I'm sure I am just over looking something simple.
Dingman.
Use a photobucket account and post the "[IMG]" code and the photos will show up
silence007
here are my tires just taking up space in the living room.  Ordered my wheels today.  I ordered pro comp 15x10 black steelies.
John Doe
silence007
Thomas P
'14 Camry SE
Dingman.
Been slackin on the pics.
And the steering box mount was made and welded on.  Almost done.
silence007
I might have just found a guy to trade me the correct t case for that v6 one I got, I also found a 36in spare super swamper tsl close to new for 40 bucks.
silence007
Wheels are in, wish i would have thought about one for my spare when I ordered them.
Thomas P
Awesome! We need to get them up here and mounted! Did you give any thought to the rear setup? We need shackle material.
'14 Camry SE
silence007
I wanted to go after work today, but I got a job added and was too late.  Where has steel like that?  I was thinking about just buying a plate of steel and attempting to build my own bumper, doesn't seem like it could be too hard.  For the rear I think just go with the 3 in forward or so, my lead for the t case hasn't came through.  For the rest I will wait untill I get everything ready and on hand to do axles, gears and cases, square front d-line and hopefully work something for rear or have that one made.
