Author Topic: Stuck gas pedal  (Read 2119 times)
sparkynacho
  • Turtle Points: -7
  • Member since Jan '07
Stuck gas pedal
« on: Sep 28, 2010, 01:00:06 AM »
Every time I press the gas pedal it gets stuck at the bottom. I find myself going under the hood and releasing it manually. Is there spring of something that I have look for to make it work on its own?
  • Turtle Points: 1128
  • Male Posts: 9,757
  • Member since Oct '04
Re: Stuck gas pedal
« Reply #1 on: Sep 28, 2010, 01:38:21 AM »
There's no golden "this is the problem" answer.  You need to inspect your complete throttle system from the pedal to the carb/throttle body to determine what's hanging up.  Seems pretty simple to me  :thumbs:
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
Re: Stuck gas pedal
« Reply #2 on: Sep 28, 2010, 03:14:20 AM »
Some more info would be needed here to even discuss the issue like year, efi/carb, etc.
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
Re: Stuck gas pedal
« Reply #3 on: Sep 28, 2010, 08:40:49 PM »
Clean and lube all pivot points. Pull cable cable and clean inside by spraying brake cleaner down the cable until it runs clear out the other end. Go to a MC shop and get some cable lube and use as directed.
46&2
  • Hillbilly
  • Turtle Points: 8
  • Male Posts: 4,834
  • Member since Dec '05
  • California livin'
Re: Stuck gas pedal
« Reply #4 on: Sep 28, 2010, 08:50:08 PM »
My cable stuck like crazy and I did this and now it works great.
zippo
  • Turtle Points: 550
  • Male Posts: 1,556
  • Member since Nov '08
    • oppiz.net
Re: Stuck gas pedal
« Reply #5 on: Sep 28, 2010, 08:56:01 PM »
just feather the clutch all the time and let it run wide open? I mean, thats what you would do if you were a real man.
:beer: just playing. Just gotta start checking stuff. should be easy to find!
If you see it, its for sale.
Sparkplug
  • Turtle Points: -130
  • Male Posts: 2,046
  • Member since Jan '08
  • Doin it Standing Up
Re: Stuck gas pedal
« Reply #6 on: Sep 28, 2010, 11:17:00 PM »
Lol, now old yotas r goin WOT huh
Plekto
  • Turtle Points: 27
  • Male Posts: 863
  • Member since Aug '07
Re: Stuck gas pedal
« Reply #7 on: Sep 29, 2010, 12:37:37 AM »
Only way to keep up with the insane commuting speeds every morning...
toolman
  • Male Posts: 194
  • Member since Apr '06
Re: Stuck gas pedal
« Reply #8 on: Sep 29, 2010, 05:55:12 AM »
What year is it?? Mine is a 82 and im running a weber so i did away with the factory linkage and use a lokar cable with the factory pedal and the weber carb linkage. had to do a little mod with the carb linkage bit it all works good and no sticky.
'82 yota work in progress
33x12.50's
Fuel Injection
4" lift
flat bed
x-over steering
full float rear
L52HD
LC engineering pro
Dr Phat
  • Turtle Points: 305
  • Member since Oct '09
Re: Stuck gas pedal
« Reply #9 on: Sep 29, 2010, 06:31:39 AM »
I had the same problem when waking my Toyota from its 26 year slumber.
Made a bowl out of tinfoil and let the throttle plate/body soak in carb cleaner overnight. Worked great after.
sparkynacho [OP]
  • Turtle Points: -7
Re: Stuck gas pedal
« Reply #10 on: Sep 29, 2010, 02:04:07 PM »
The car was parked in my driveway for a few years. I will try to lubricate the throttle cable. The linkage attached to the intake manifold work fine.
Last post Mar 11, 2003, 06:27:11 AM
by vikingsven
Last post Apr 12, 2004, 10:03:59 PM
by 4.3 headache
Last post Oct 25, 2007, 05:59:00 PM
by Burl
Last post Apr 05, 2008, 08:33:04 PM
by REG535
Last post Jan 30, 2013, 12:49:59 PM
by 81_Toy4x4
