Author Topic: Junk new weber to efi?  (Read 3377 times)
1badeagle
  • Turtle Points: -1
  • Member since Mar '09
« on: Sep 17, 2010, 01:23:28 PM »
Hey guys, I just picked up a 88 donor truck for 50$ with a bad motor. My question is, Im about to swap the junk weber out for the efi off my donor truck. I have a 85 4runner, with a different motor in it that i built. I need to know what year the motor actually is. I know that it has the volcano pistons and a double roller timing chain. So is my motor not going to have the holes needed to bolt on my efi stuff? How hard is it to add the needed holes to my exsisting built head? Will there be much of a power gain from a bad running new weber to the efi setup?Are there alot of wires that will need spliced?
Thanks alot guys.
Dustin Phillis
P.S. Add anymore input if you can:)
superyota
  • Prestige Worldwide
  • Turtle Points: 71
  • Male Posts: 3,362
  • Member since Oct '05
  • what happened?
    • Placer County Crawlers
Re: Junk new weber to efi?
« Reply #1 on: Sep 17, 2010, 02:04:21 PM »
i swapped my 85 from carb to efi about 5 or so years ago.  i didn't have to do any mods to the head. 85 was the cross over year where the head is already tapped for efi manifold. but there is a whole bunch of wires that have to get spliced.  it seems kind of overwhelmng at first, but its really not too much.  it took me about 4 hours of soldering alone.  had the harness swapped out in less than a day though.  it was well worth it.  if you need any help, let me know.  i still remember it like i did it yesterday.  getting ready to do another here pretty soon.
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
superyota
  • Turtle Points: 71
  • Male Posts: 3,362
  • what happened?
« Reply #2 on: Sep 17, 2010, 02:06:27 PM »
oh, best way to do it, have both trucks parked side by side. don't forget, every wire from headlight to tail light is going to get swapped over.  even the guage cluster will need to get swapped over along with relays.
ABD Motorsports
#4475
KK6QDW
1badeagle [OP]
  • Turtle Points: -1
« Reply #3 on: Sep 17, 2010, 03:06:11 PM »
Is there a way to make a simplified harness??
superyota
  • Turtle Points: 71
  • Male Posts: 3,362
  • what happened?
« Reply #4 on: Sep 17, 2010, 03:17:51 PM »
yes, but its more work than its worth.  ORS had one, but i think they went out of business.  you could have everything(harness, ecu, gas tank, etc.) swapped out in a weekend.  as long as your parts truck has a complete wiring harness, i would just go with that and swap it all over.  there is a post up somewhere on pirate where a guy integrated a carbed harness with the efi harness and made them work.  i'll see if i can find it.  like i said though, its more work to do it that way than to swap the whole harness over.  just my :twocents:
ABD Motorsports
#4475
KK6QDW
1badeagle [OP]
  • Turtle Points: -1
« Reply #5 on: Sep 17, 2010, 03:38:02 PM »
Ok, I found the post on pirate and have read it all. Does it matter if my donor truck has a auto tranny and not a manual? Also any idea on the year of my motor?
superyota
  • Turtle Points: 71
  • Male Posts: 3,362
  • what happened?
« Reply #6 on: Sep 17, 2010, 03:45:53 PM »
no, auto tranny doesn't matter.  you'll just have some extra wires and plugs that you can snip off or zip tie up.  88 efi should be the identical.  everything will swap right over.  85 was the first year that the 22re was out in the trucks, and the heads regardless if they were carbed or not are tapped for it with the extra bolt or stud, i don't remeber which.
ABD Motorsports
#4475
KK6QDW
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #7 on: Sep 17, 2010, 04:35:14 PM »
Thanks alot guys.
Dustin Phillis
your engine was made before August of 84.  the holes might be there but i cant be sure, if it was a 84 engine then they probably would but if its a 82 or 83  probably not.
all you need to swap is the engine harness and ecu
superyota
  • Turtle Points: 71
  • Male Posts: 3,362
  • what happened?
« Reply #8 on: Sep 17, 2010, 04:37:25 PM »
and body harness.  unless i did more than i was supposed to?   :dunno:
ABD Motorsports
#4475
KK6QDW
« Reply #9 on: Sep 17, 2010, 04:38:53 PM »
the 88 efi is unique,  it has a different plug on the injectors so if you use a 88 efi harness you'll have to use 88 injectors also.
not 100% sure on the auto tranny wiring but i'm pretty sure you have to wire in the neutral switch so it will start.
« Reply #10 on: Sep 17, 2010, 04:42:12 PM »
body harness's are the same,  he only needs to remove the pass side kick panel and remove the ucu, then move the harness from the engine to the ecu.
however I cant remember where the wires connect to that engine harness for the gauges :headscratch:
superyota
  • Turtle Points: 71
  • Male Posts: 3,362
  • what happened?
« Reply #11 on: Sep 17, 2010, 04:46:08 PM »
i'll look at mine when i get home tonight, but if i remember right, the engine harness has 3 plugs, 2 of which plug into the ecu, and the the third plugs into the body harness, then another plug from the body harness plugs into the ecu also.  i'll check though, i might be wrong
ABD Motorsports
#4475
KK6QDW
1badeagle [OP]
  • Turtle Points: -1
« Reply #12 on: Sep 17, 2010, 05:00:13 PM »
Ok, pirate says that you must use a 83 and up head, thats why i was asking since I have no clue what mine is. If you guys were gonna do this how would you rate it on a 1-10 scale 1 being easy and 10 hard?
Sparkplug
  • Turtle Points: -130
  • Male Posts: 2,046
  • Member since Jan '08
  • Doin it Standing Up
« Reply #13 on: Sep 17, 2010, 08:41:29 PM »
I say it a 5, can vary depending on how u doin it. If u got a whole donor truck its easy peezy. If you cuttin and splicing wires to build a harness, can get a lil more tricky, and then when u run into probs, can be harder to find.
1badeagle [OP]
  • Turtle Points: -1
« Reply #14 on: Sep 20, 2010, 08:11:11 AM »
I only paid 100 bux for a entire 88 2wd 22re automatic with a 120k miles on it. The bed and frame are rusty but the doors,cab, fenders are all rust free. I gonna swap the doors onto my 85 runner and sell the cab and fenders and scrap the converter. I think I got a awesome deal on it for 100$.
Last post Jul 10, 2005, 08:25:13 PM
by chevyLUVtoyota
Last post Jan 31, 2005, 10:04:25 PM
by MUDJUNKY
Last post May 20, 2006, 09:46:35 PM
by TrikeKid
Last post Jan 09, 2007, 08:36:38 AM
by thefreqofnature
Last post Dec 26, 2007, 04:40:03 AM
by MarkyB
