Warn 8274
Started by Peterbuilt84, June 29, 2010, 08:40:11 PM
Peterbuilt84
I am seeking some help. I ended up getting a winch for free and when I looked it up to see what it was it turned out to be a Warn 8274  :o. It looks to be in decent shape, but I have no idea how to see if it works or to check what condition its in. Can anyone help me out?
Thanks
joey0712
They work good. A friend of mine runs one. They are pretty fast thats all i remember.... Hell you cant beat free.
91 Toyota High pinions f&r.
bleakhorizon
8274's are awesome winches...  fast, reliable, huge, hard to mount without sacrificing ground clearance.  if your really into in you can get aftermarket drums, gear kits, motors (double motor kits), air actuated freespool... There is a reason why alot of the winch challenge guys use these winches...
there are people that run them on there yotas... usually they stick pretty far out there... Unless you have your radiator somewhere other than stock than you wont be able to suck it any further in than i have mine..
the motor is about inch away from the radiator guard which is bout 1/2 inch away from the rad.. so you could get closer...
Those are some huge welds!
Tillamook, OR
Peterbuilt84
Thanks for the info. I've been looking at how to mount it and it seems like it might be kinda hard.
2manytoys
Get the serial number off the ID plate and download the parts and operation manual from Warn's web site.
There is a rebuild kit available to replace the seals and bushings that is usually about $50 from a 4x4 shop but I found one on Amazon for $19 and it was a genuine Warn Kit. Get 150 feet of new 3/8" wire rope or synthetic rope if you got the bucks if the stuff on it is bad.
I modified a Smittybuilt tube bumper to mount it. I got it as close to the grill as possible. I didn't want to remove the grill or A/C condenser like some people do to tuck it in tight.
Some people might not like it but it works for me. Yeah, I know the lights are not in the best spot but they work for me too.
Here's some pics. The bottom matches the angle of the skid plate when it's on.
bleakhorizon
had to dig way back for this pic... but i modified a smittybuilt to accept the 8274 also.. never liked the way it was attached but i used it to winch a few people out.
yet again no grill.... to tell yea the truth most my yotas i take the grills off.... just dont like em i guess lol
Tillamook, OR
Peterbuilt84
Thanks for the pics. I had a smittybilt but am gonna get rid of it, just not for me.
-Jake-
Here is how I did mine.  Bent up my own tube bumper.  It does hang way out there but man it winches in a hurry.  I love it :)
Peterbuilt84
Wow that looks good, doesn't look like it sticks out too far at all. Got any more pics? I was thinking about making something out of plate since I don't have a bender. Only problem I see is its going to be super heavy.
-Jake-
Peterbuilt84
Thanks for the pic, looks good :thumbs:
mtm
they are the dogs dangleys of winches. all the chalange trucks run them over here in the uk because of the line speed and 150 foot of cable. you can get uprated motors or run a dual motor setup.
i have made up a tube bumper for a mate to run one on his truck
hilux 82 with mk3 2.4d engine. bobed 18 inches, full soft top, 9 inches of lift,exo cage,swing out tyre carrier, front tube winchbumper with x9, rock sliders, rear tube bumper, front truetrac and rear arb lockers, twin trans adapter with 4.7 crawler gears,20 forward and 4 reverse gears, 38 inch super swampers , rear disc brake conversion, trans disc parking brake, 5.29 r&p ,rear bench seat,hand throtle,custom storage boxes, custom made snorkel,onboard air compressor,cb twin bateries,split charge system, diff guards, low profile gearbox mo
sirhc0306
i had one on my truck. i modifyed a Marlin bumper and it worked great.
92 SAS truggy, Dana 44 Detroit 5.38's, 3 link with 14in Kings, Rear 9in Spool 5.42's, 3 link with 14in Kings, 22RE, SM465, 23 spline 2.28 and 4.70. 39.5 Iroks on OMF beadlocks. Warn 9000
meridian
Best winch out there. Even thought they are big , gotts wear em proud :beerchug:
