The diffs are professionally setup. I have solid pinion spacers, oil slingers. The gears are not but the bearings and races are heat treated. The gear sets are Yukon. Welded rear and a Detroit truetrac in the front. The rig is a 89 reg cab with a custom tube box. 3" body lift, 5" spring lift, 6" shackles. 36" Irocs. drivetrain Gm 350 TBI 700r4 Toyota case 4.7 low gears.
Enjoy the lighter axles heaver axles more wieght to pull around. Maybe dynatrac rock pro44
Yeah a limited slip is hell on gears. one tire will be spinning and then the limited slip finally hooks up and transfers power to the other wheel, and snap!
Started by vikingsven Parts Wanted
Started by BCB Parts For Sale
Started by toy85ota Toyota Pickup/4Runner Tech 1979-95
Started by crawler925 Parts For Sale
Started by 591fab Parts Wanted
