Author Topic: 22re oil recommendation  (Read 34751 times)
88yota
  • Turtle Points: -2
  • Male Posts: 83
  • Member since Apr '10
« on: Jun 01, 2010, 04:19:49 PM »
Hey guys-
I wanted to see/get recommendations on what kind of oil you run in your 22re during the summer. I live in northern California so the temp. in the summer ranges from 85-100+. I've read the manuals and what not, but I still want to see what you all recommend or are running.
Thanks
2slow4you
  • Male Posts: 105
  • Member since Oct '07
  • I got the Jeep thing, now it burns when i pee!
Re: 22re oil recommendation
« Reply #1 on: Jun 01, 2010, 05:41:48 PM »
10w40 changed every 3k miles
88yota [OP]
  • Turtle Points: -2
  • Male Posts: 83
« Reply #2 on: Jun 01, 2010, 05:45:07 PM »
Do you run that year round...or just summer?
2slow4you
  • Male Posts: 105
« Reply #3 on: Jun 01, 2010, 05:48:43 PM »
year round. You could go a bit lighter but I've found this to be a happy medium.
  • Turtle Points: 7571
  • Male Posts: 3,561
    • emsvitil's album
« Reply #4 on: Jun 01, 2010, 06:11:33 PM »
How many miles on the engine?
I have 170,000 and am currently using 15w40 diesel oil (chevron , think it's called delo) for the zinc additives......
88yota [OP]
  • Turtle Points: -2
  • Male Posts: 83
« Reply #5 on: Jun 01, 2010, 06:15:45 PM »
rebuilt, probably about 6,000
  • Male Posts: 3,561
    • emsvitil's album
« Reply #6 on: Jun 01, 2010, 06:43:48 PM »
If you're not towing or hauling a lot of crap.
10w30
or even
5w30 synthetic
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Lego Enforcement
    • Spinnin4s 4x4 Club
« Reply #7 on: Jun 02, 2010, 12:31:13 AM »
If you have a high mileage engine go with a non-synthetic high mileage motor oil, it does work. You don't need any other additives when you use it and it provides the same protection from leaky seals. I run Castrol 10w/30
fade
  • Turtle Points: -9
  • Male Posts: 1,018
  • Member since Oct '09
« Reply #8 on: Jun 02, 2010, 03:04:04 AM »
Pretty much will run on anything you wanna put in from 5/30 to 20/50.
In my past 3 yotas I've ran castrol gtx high mileage 10/30. My current one I'm running Moblie one 20/50 trying it out but going to switch back... I'v been running napa's gold oil filters which help cut down on the start up rattle of the chain.
What do you all run for filters?
86 mini truck 18" rays
09 highlander
70 suburban
YotaNate
  • Male Posts: 276
« Reply #9 on: Jun 02, 2010, 10:19:23 AM »
I run Mobil One 10/40 with the BIG K&N filter, I forget the number.  :twocents:  Always had good luck with it.
Nate
"A CNN reporter, while interviewing a Marine Sniper asked.  What do you feel when you shoot a terrorist"?
The Marine shrugged and replied, "Recoil."
SolidAxle
  • Turtle Points: 6
  • Male Posts: 365
  • My truck is 5 years older than me
« Reply #10 on: Jun 02, 2010, 11:29:34 AM »
I run 10w30 mobile 1 with the large toyota filter. i used to order the HUGE fj40 ones but a recently scored an oil cooler off of a turbo truck so i use the smaller one. i might even use the regular filter specd for the engine from toyota
fade
  • Turtle Points: -9
  • Male Posts: 1,018
« Reply #11 on: Jun 02, 2010, 02:03:16 PM »
It sucks though because the oil filter with the valve for keeping oil pressure to keep the chain start up rattle away is discontinued. Or thats what I've been told by my local stealer-ship.
09 highlander
70 suburban
  • Male Posts: 3,561
    • emsvitil's album
« Reply #12 on: Jun 02, 2010, 02:10:51 PM »
The very common Purolator L30001  (what was once called PUR1A).
Also use same filter on my 64 Plymouth Valiant.
Travis H
  • Turtle Points: -367
  • Male Posts: 789
  • Member since Sep '08
  • 5100 ft
« Reply #13 on: Jun 02, 2010, 03:57:08 PM »
castrol gtx high mileage 10w-40 with a mobil1 oil filter 60k on rebuilt motor.
« Reply #14 on: Jun 02, 2010, 04:13:51 PM »
summer in Arkansas = lows in the 70's at night and highs anywhere from 90-110 with 80 % humidity possible
I always run Castrol 20/50 in the summer months and Castrol 10/40 in the fall/winter/spring
Cheesemaker
  • Turtle Points: 1363
  • Male Posts: 4,525
« Reply #15 on: Jun 02, 2010, 04:38:41 PM »
I run the Delo 400 30 wt.  It usually doesn't get that hot here on the Oregon Coast for me to run anything else.  And I feel that oil for diesels (20W-50) is too thick and has all the wrong properties for a gas motor.  I stick with 30wt, since I change my oil every 2500 miles, and then reuse the old oil for my my chainsaw for bar oil.  And I run Carquest filters.  They got the anti-siphon valve.  And get the large filter, which for some reason is listed as a 85 4runner.  For some reason that is the only year that they list a larger filter for any 22r/re.  All others listed for a smaller one.
But a search here found these postings:
http://board.marlincrawler.com/index.php?topic=50809.0;highlight=oil+filter
http://board.marlincrawler.com/index.php?topic=46220.0;highlight=oil+filter
http://board.marlincrawler.com/index.php?topic=32698.0;highlight=oil+filter
« Last Edit: Jun 02, 2010, 04:44:37 PM by Cheesemaker »
briaN.
  • Male Posts: 16
  • Member since Aug '10
« Reply #16 on: Sep 02, 2010, 10:51:34 AM »
i run 30 wt also
Don't worry the operation won't take long..and you'll be much better in the morning
yotarunner85
  • Turtle Points: 6
  • Male Posts: 166
  • Member since Nov '09
  • San Diego, CA
« Reply #17 on: Sep 03, 2010, 08:46:21 AM »
I run 10-30 oil and a larger oil filter, ether a Motorcraft FL-1A or the Fram PH8A.
1985 Toyota 4Runner, BFG 35" MTs, 4" lift, Detroits lockers front & rear,5.29, V6 rear, rebuilt 22RE.
  • Turtle Points: 1128
  • Male Posts: 9,757
« Reply #18 on: Sep 16, 2010, 01:33:54 AM »
Currently running 20/50 redline synthetic in the 80 with a napa gold (wix) 1068, the larger one that's for a 302 I believe.
Run 10/40 or 10/30 valvoline/mobil in the 91 all year long with the same 1068 filter.
mikeaguirre922
  • Turtle Points: 8
  • Male Posts: 24
  • Member since Sep '10
« Reply #19 on: Sep 18, 2010, 09:28:35 AM »
either 10/30 or 10/40 will be just fine
1988 4runner 22re 5 speed 210,000
add a leaf, shackles, torsions tightened,
31's on black steelies, lc header, lc cold air
intake, magnaflow cat, lc muffler, lc cam, system
2 12's, 2 7" kragen hids, procomp light bar
http://s206.photobucket.com/albums/bb125/mikeaguirre922/4runner/
« Reply #20 on: Sep 18, 2010, 09:38:43 AM »
Castrol 20/50 is NOT a diesel oil its designed for high mileage small engines such as the 22R, Chevy 2.5L  etc
Actually  if I'm not mistaken isnt all Delo 400 diesel oil :dunno:  I know Delo 15/40 is what my boss always ran in a couple of my big rigs i drove.  the only other oil was Rotella 15/40
the 15/40 is almost ALWAYS a diesel oil and has additives to clean the soot out of diesels
Plekto
  • Turtle Points: 27
  • Male Posts: 863
  • Member since Aug '07
« Reply #21 on: Sep 21, 2010, 10:44:31 AM »
I run cheap 10/30 and an oil conditioner like Lucas(start-up rattle is gone).  But this engine has 200K on it.  Runs very well for its age.  The big deal is to change oil often, since the engine is not as well sealed or as tight on its tolerances as modern designs.  A *lot* of grime gets sucked into it.  Even at 3K miles, the oil is nearly twice as dirty as my dad's 10 year old Buick.
Last post Oct 19, 2006, 08:15:42 PM
by Ranski
Last post Oct 21, 2006, 08:57:26 PM
by 4XFlyin
Last post Sep 24, 2007, 02:54:13 AM
by Goose
Last post Nov 02, 2011, 11:28:47 AM
by Rydell
Last post Jun 27, 2020, 11:08:25 PM
by Winky29
