check it out!!! 84 extra cab 37"mtrs suggestions???
Started by mxer833, April 30, 2010, 12:17:54 AM
mxer833
 :welcome: :welcome:i started my build with an 84 extra cab with 33's stuffed in with drop shackles and blocks in the front. so i got a trail-gear 5'' lift. bilstiens all around,long spline front driveline, 37" wrangler mtr's on black 15x8 steelies, 1.5" wheel spacers. spencer doodle hooked up a custom rear shock tower for the 14" bilstiens 5150's, high steer, ifs box
This is me on the right and my buddy donnie on the left starting in on the beginning stages of my build. starting on getting rid of all the rust. it was sitting in a field, and sat by the coast for a while so there was alot of frame rust, but no permanent damage
RUST BUCKET!!!!!!
i plan on dual cases, rear disc brakes, v6 calipers and rotors in front, rock sliders front and rear bumpers, exo-cage, line lock,and winch. thats it for now but definitely propane injection when its not my dd.
right when we finished the lift, CLEAN!!!
SPENCER DOODLES custom rear shock tower
this is what my axle looked like before i started in on it
:welcome: :welcome:
my truck when it first got the lift and new shoes!
fade
86 mini truck 18" rays
09 highlander
70 suburban
yjay
22re Daily Driver
http://board.marlincrawler.com/index.php?topic=56568.0
91 4Runner-R151f, MC07,23 spline duals, Marlin 1200lb clutch, 85 Front axle, Leaf swap rear, Yukon 5.29's, BFG KM2 35's, Detroit, OBA, 280k
bigarms23
mxer833
thanks guys, ya i know all about trail-gear.i started my lift before i knew about the materials trail-gear uses, but only my hardware came from them. i know about the china bearing, so when i do dual cases or adapters im definitely goin through marlin crawler.
Yoat Goat
T urning
O ver after
Y ears
O f
T rail
A buse
gtoyonrocks
That is a nice looking second gen. Can't wait to see more.
Peterbuilt84
Looks good, nice rig. What did you for the rust on the frame? Trying to build up my 84.
greg_k113
boomtacoma01
Gotta agree with this guy^
That is the direction I have planned for my 85 E/C EFI.
85 Ext Cab 22RE, 3 Linked front D60, 14B, Full Hydro and 40s
IG @boomtacoma01
91 ex-cab
That is absolutely hands down my dream truck right there, I truely am jealous of that it looks like the ferrari of toyotas to me :bowdown:
jackson58
Looks good  :cool: other than the front crossmember. I personally would have decreased the gap between it and the frame. Needs more attatchment points other than just at the ends and bracing on the backside would be good also.
Dirt is for wheelin not for wearin you filthy hippie!
PBrown
91 reg cab sas, duals 4.7, 5.29s, detroits, 35s, bunch of marlin debt.
swapped89
I dig it man Truck looks :boobs: :thumbs: my suggestion,  get some armor on there before you wrinkle that pretty sheet metal.
SAS 89 p/u 3.0 5speed, bobbed, locked, ready to play in the rocks. or wherever the pavement ends :)
http://board.marlincrawler.com/index.php?topic=61345.0
a wise man listens and observes more so than he opens his mouth.. and when he does it is valuable information....   (twistedtoy92)
thegoofster21
Quote from: crawlerdad on October 08, 2009, 08:21:17 PM
Any guy who takes his woman wheeling enjoys her. A woman who is owned is left at home to cook, clean, and keep beer cold. So if this offends you you should stop looking and go have some tacos.    :rofl2: And a beer. If your old enough.   :beerchug:   :beer:
04 Tacoma 33s http://board.marlincrawler.com/index.php?topic=61454.0
jmoffroad.com
tanman85
mxer833
thank you guys, the comments are great to hear. alot of hard work went into it. i used like this spongy sand paper on a drill tip for most rust. also since i last posted pics ive got both axles armored, chevy disc brakes in rear, spare tire, rock lights, kc slim highlights, and a new front bumper. in the process of building new rock sliders wit some square steel. ill keep posting new pics. thanks again guys.
86sasturbo
"If you cant fix it with a hammer you more than likely have a electrical problem."
89sastoyo
I would say you need to get a piece of flat bar and weld it to the hanger and core support area.. It looks like you only welded the outside corners of the hanger.. I pulled my frame apart right in front of the steering box a while back so with that amount of tension it could pottentionally rip that hanger right off.. Thats my suggestion other than that, that thing looks good. I agree with swapped89 get  a rear bumper and some sliders on that thing asap or say bye bye to that clean bed and rockers.
89 extra cab stock on 1 tons.
92 2wd DD
first gen cab
Check out the build.
mxer833
oh i really should keep up on this, i flopped the pick up fixed it and now its my trail queen, i need to post the pics of the 86 4runner ive been building! and as for the hanger its been fixed since someone mentioned it a while back, also moved it 3'' forward which helped alot! AND  its welded all the way across. ill post pics of the runner soon!
86sasturbo
