Author Topic: 10" Travel shocks  (Read 3954 times)
greg_k113
  • Turtle Points: -49
  • Male Posts: 224
  • Member since Feb '10
10" Travel shocks
« on: Apr 18, 2010, 06:01:42 AM »
All right I'm doing a SAS on a 1993 Extended cab. I'm doing it on a budget so I plan on using waggy springs and using F-250 shock towers. The question is I aquired some Rancho shocks to use in the front they are RS 5143 and have 10" of travel would they work ok with stock waggy springs. I know most people use 12" or 14" travel shocks but I just want to know what you guy's think. Also I live in central Pa so I wont be running all those extreme trails you guy's have out west. Thanks for any input.
86bobbedtoy
  • Turtle Points: 686
  • Male Posts: 3,938
Re: 10" Travel shocks
« Reply #1 on: Apr 18, 2010, 07:41:29 AM »
 if you mount them perfectly,
with only 2" uptravel.
set up like this /\
I think it will be ok.
Im running 14s /\ 3" uptravel and I dont use all of them at drop
TacoRunner
  • Turtle Points: 19177
  • Male Posts: 2,324
  • Member since Feb '04
  • The 1st 3RZ swap 99'-01'
    • 4wheelunderground
« Reply #2 on: Apr 18, 2010, 09:01:11 AM »
Chuck'em, get new ones
www.4WHEELUNDERGROUND.com
info@4wheelunderground.com
lilbuddy
  • Dried Fruit Warrior
  • Turtle Points: -234
  • Male Posts: 5,720
  • Member since Aug '04
  • Hella....
« Reply #3 on: Apr 18, 2010, 09:10:54 AM »
x2..
10 inch is way too little in the front. On my old 4runner which was pretty low, i had f250 shock towers and only 14" shocks worked for it
RIP Kyota.... you are the man
GET IT!!!
TacoRunner
  • Male Posts: 2,324
    • 4wheelunderground
« Reply #4 on: Apr 18, 2010, 09:30:10 AM »
I had AllPro springs front and rear, and they moved pretty dare good. On the front I mounted the shocks in the factory posion on the axle. And had bump stops set to zero arch for the springs. Under compression I had 1/8" of shock shaft showing, under full droop I had a full 10" of shaft showing. So I guess it would work but good luck mounting it that close to dead on. Go get some 12"s and make life easy for yourself.
kauaikid
  • Male Posts: 267
  • Member since Dec '04
« Reply #5 on: Apr 18, 2010, 12:07:28 PM »
i'm running the allpro extreme 4" kit with 10" shocks up front and havent had any issues and the travel is great for the more mild to moderate trails i drive on here.
84 longbed, lc eng. top end kit, dual cases w/ 4.7 in rear, arb's front w/high pinion and rear with v6 diff., 5.29's w/ 35s, all-pro long travel 4" and much more
greg_k113 [OP]
  • Male Posts: 224
« Reply #6 on: Apr 18, 2010, 12:55:22 PM »
How many inches of the shock is showing?
TacoRunner
  • Male Posts: 2,324
    • 4wheelunderground
« Reply #7 on: Apr 18, 2010, 09:54:17 PM »
There are more than a few factors with that one, dont worry about that. When setting up your suspension, set your up travel with the shock and bump stop, at that point droop is just iceing on the cake. If at some point you think travel is limited by the shock length the you can re-approach it.
kauaikid
  • Male Posts: 267
« Reply #8 on: Apr 19, 2010, 01:15:09 AM »
i just went out and took a tape measure to it and it's right about 7" but at the moment there's no motor in the truck so i'm gonna say 6" normally.  I'm also running all-pro shock hoops.  I did look at marlins kit and looks like they go with 12" unless specified so i'd have to guess you'd be safe with 12" shocks as well.
TacoRunner
  • Male Posts: 2,324
    • 4wheelunderground
« Reply #9 on: Apr 22, 2010, 07:52:29 PM »
I'd say with the motor it would be more like 5"
greg_k113 [OP]
  • Male Posts: 224
« Reply #10 on: Apr 23, 2010, 07:07:43 AM »
Does it flex ok with 10" shocks?
TacoRunner
  • Male Posts: 2,324
    • 4wheelunderground
« Reply #11 on: Apr 23, 2010, 07:24:27 AM »
See below...
MiniSimp
  • Outdoor Enthusiast
  • Male Posts: 5,120
  • Member since Jan '05
  • SimpsonBrothers.net
« Reply #12 on: Apr 23, 2010, 07:36:10 AM »
I'm running 14's in the front, 3" uptravel, 11" downtravel and max them out. My front shocks act as limit straps. If anything I need 16's.
RUF btw.
Last post Jul 29, 2004, 03:26:41 PM
by Hyena
Last post Apr 02, 2005, 07:40:40 PM
by yotaboy79
Last post Aug 30, 2009, 06:19:40 PM
by SWAMPER
Last post May 12, 2010, 07:44:59 PM
by Bert Vega
Last post Jan 21, 2011, 10:47:16 AM
by GloNDark
