start searching grounds
there is like a fuse/relay type thing above the fuse box next to the door buzzer check that!there is also a relay on the passenger side above the ecu you have to take the glove box out to get to it
did you try the air box there is a flap in there if it dosent sense air flow it will not turn on, and check the fuel pump relay under the hood, its the closest round silver thing with a bronse dot atop of it on the passenger side by the battery, the other relay facing the driver side is your fan relay. if its loose or bad you dont get spark!
try manually opening the gate on the mass afm.also pull out the efi relay and use a jumper wirejump it across diaginally, theres 2 ways but only 1 will work.the other might pop a fuse, it it does replace the fuseand try the other way.that manually kicks onfuel pumpigniterinjector circuit
Started by lowgeared Trail Reports, Events, and Gatherings
Started by JCTACO Toyota Tacoma/4Runner/T100/Tundra/FJ Cruiser 1995+
Started by AZ 4X4 Engine
Started by GrindingRock Axle/Differential/Steering
Started by bryanrz Axle/Differential/Steering
