add-a-leaf
Started by yota18, March 25, 2010, 12:19:36 AM
yota18
Has anyone used these i was just wondering if it would help my rig because my front leaf springs are arched negativly.
They tend to create a hard ride and can break springs. That being said I have done them front and rear plus a shackle lift for a quick pick me up for larger tires.
yota18
GNasty 82
Quote from: Rocksurfer on March 25, 2010, 01:21:44 AM
x2
I had a similar problem with my fronts being negative arched when I bought my truck.  I added the add-a-leaf to the front as a temp fix until I can afford my Marlin springs.  It definitely makes for a rough ride on the street and the flex is hindered as well.
82 Toyota SR5 Pickup
  Marlin Dual Ultimate
  Front 5.29 LC HP Elocker
  Rear 5.29 Grizzly Locker
  BFG 37" KM2s
  Custom rear frame and flatbed
  Propane Powered.
Build Thread:
http://board.marlincrawler.com/index.php?topic=64521.0
Quote from: Toymin8r on July 19, 2010, 02:18:05 PM
"The two enemies of the people are criminals and government, so let us tie the second down with the chains of the Constitution so the second will not become the legalized version of the first."-Thomas Jefferson
I made one for the rear of my 2wd.  I took a full leaf from the same truck, cut off the ends, beveled them so they wouldn't cut into the other leafs and put them just under the top leaf.  I gained a positive arch with minimal difference in ride.
yota18
cool thanks i am thinking of doing this just as a temp fix right now. thanks for the input
Snowtoy
Do as kneedownnate suggested, and don't waste the money on after market add-a-leafs.  You should be able to rebuild both of the fronts, even add in some lift for less than $30(used leaf pack and 2 new center pins).  You can usually gain about 1" of lift/extra leaf, and as long as you use the longest leaves, you shouldn't stiffen the ride too much.
A much better suggestion from 'Nate, those market add-a-leafs suck. Downey made an excellent "extra leaf" that was a long leaf and not just a load leaf, but sadly they are gone now.
wesley
add a ;eaf is as good as a feef in october... on the grownd and getting raked up into a trash pile. just add your own leaf. like it was said. use a longer leaf from a stock toyota rear pack. add it in and you will regain some of your spring rating and a little ride hight. dont be bashfull you might want two. much cheaper than buying a kit. and you would hate yourself if you used an aftermarket add a leaf. it will destroy the truck.
Snowtoy
You also don't have to use Toyota leaves, almost any set of leaves you find can be used.  I like to use the chevy packs(IIRC they are about 54" long), they are a little wider, but not enough to cause problems w/u-bolts, and a little thicker at 3/8" thick.
#10
stay away from the leaves that are 3/8 inch thick, Ive used 2wd chevy S10 springs and 2wd F150 springs as add a leafs, (1/4 inch thick) keep them as long as possible and you'll be fine
i had some cheap "add a leaf"  a long time ago,  there were about 24 inches end to end and about a 1/2 inch thick,  rode like hell and made the stock springs form a W
Snowtoy
The 3/8" main supports about 230lbs.  One cut to fit under each of the Toyota mains for the front shouldn't stiffen the ride at all, especially given the current state of his front leaf springs.  I run a 3/8" thick spring under the rear main in both of my 4x4's, to carry the extra weight, and it was only after I added the 2nd 3/8" spring to the '91(sagged too much when loaded w/gear) that it stiffened up the ride enough to notice it when empty.
