Author Topic: steering has a mind of its own  (Read 3370 times)
wesley
  • Turtle Points: -1
  • Member since Mar '10
  • you gotta get a little mud on the tires
« on: Mar 10, 2010, 12:40:50 AM »
i have a 90 4runner with some steering problem. i get no assistance from the power steering like its not there. then sometimes when i try and turn the wheel it rips out of my hands and turns itself all the way to lock in the opposite direction. ive replaced the pump already. didnt seem to help. anyone ever herd of this before. its driving me nuts because i cant even drive it.
yotaneck13
  • Mr. Right NOW
  • Turtle Points: -52
  • Male Posts: 2,300
  • Member since Nov '09
  • MR. RIGHT NOW
Re: steering has a mind of its own
« Reply #1 on: Mar 11, 2010, 07:12:37 PM »
mine has been doing this also not that extreme tho i wont have pwr steering then all of a sudden i do causing me to over steer idk i replaced pump also mabye the box its self?
axled89
  • Turtle Points: 296
  • Male Posts: 2,526
  • Member since Jan '09
« Reply #2 on: Mar 11, 2010, 08:28:23 PM »
maybe you feed it after midnight.
i love oregon wheelin.
yotaneck13
  • Mr. Right NOW
  • Male Posts: 2,300
  • MR. RIGHT NOW
« Reply #3 on: Mar 11, 2010, 09:34:02 PM »
im lost completly with mine its a 90 as well but truck 22re i can usually figure :pokinit: out idk
wesley [OP]
  • Turtle Points: -1
« Reply #4 on: Mar 11, 2010, 10:13:20 PM »
yeah mine is v6 and i always figure everything out too but not this. i have changed the box and the pump twice. i mean i have gone through this thing over and over. no progress. and its not that complex of a system
-Jake-
  • Turtle Points: 9
  • Male Posts: 538
  • Member since Oct '09
« Reply #5 on: Mar 11, 2010, 10:16:22 PM »
sounds like something is binding post pictures
wesley [OP]
  • Turtle Points: -1
« Reply #6 on: Mar 11, 2010, 10:23:51 PM »
no theres no binding. the box is relocated and the high steer is all set up correctly and it all worked great. until this happened. i think something got clogged. and i hardly trust a remanufactured one year warranty power steering pump. there was an abs actuator that is operated by power steering fluid pressure. it had a pressure line in and one out and then went to the steering box. i got rid of all that a while back and had a custom one piece hydro line made. and it all worked after that.
-Jake-
  • Turtle Points: 9
  • Male Posts: 538
« Reply #7 on: Mar 11, 2010, 10:27:01 PM »
I've been drinking but is it possible to hook the lines up backwards on the steering box?
wesley [OP]
  • Turtle Points: -1
« Reply #8 on: Mar 11, 2010, 10:55:40 PM »
umm funny u say that because i did it once...after drinking. not the problem here
-Jake-
  • Turtle Points: 9
  • Male Posts: 538
« Reply #9 on: Mar 11, 2010, 10:56:58 PM »
 :beerchug:   :rofl2:
I'm trying to be helpful...
wesley [OP]
  • Turtle Points: -1
« Reply #10 on: Mar 11, 2010, 10:57:41 PM »
haha. chears
yotaneck13
  • Mr. Right NOW
  • Male Posts: 2,300
  • MR. RIGHT NOW
« Reply #11 on: Mar 12, 2010, 06:22:54 AM »
ya def no binding in my case either as its still all stock...i do have my tbars cranked a lil to clear 35's im gonna replace pump again and box next weekend and see
wesley [OP]
  • Turtle Points: -1
« Reply #12 on: Mar 12, 2010, 08:59:09 AM »
let me know how it goes because i think i will end up doing the same thing... again
86toyota
  • Turtle Points: 2
  • Male Posts: 353
  • Member since Nov '07
    • Montana 4x4 Association
« Reply #13 on: Mar 12, 2010, 07:25:31 PM »
hows your alignment and or tire wear. My alignmnt was off for a while causing my tires to wear bad on the inside (85 axle) and it would do the same thing. I also replaced the box with a used one from a buddy and just by doing that it steered better...it would actually return to center
T86OTA
wesley [OP]
  • Turtle Points: -1
« Reply #14 on: Mar 12, 2010, 09:09:49 PM »
i wish my problems were that simple alignment is perfect. this truck litteraly was built extreme and done right. i even still drove it daily till i got a dodge to tow it with. i let it sit for a while and started having problems. im just gonna start over with this power steering im determined something is clogged and not letting pressure through.i think there is back pressure on the pump because the throttle kick up on the pump sprung a leak. its got to be a plugged up box
86toyota
  • Turtle Points: 2
  • Male Posts: 353
« Reply #15 on: Mar 12, 2010, 09:45:48 PM »
sounds like it. cross your fingers
T86OTA
Dr Phat
  • Turtle Points: 305
« Reply #16 on: Mar 15, 2010, 12:51:49 PM »
Could maybe be a combination of caster and clogged veins in the PS possibly?
Just my less than 2 cents.
yotaneck13
  • Mr. Right NOW
  • Male Posts: 2,300
  • MR. RIGHT NOW
« Reply #17 on: Mar 15, 2010, 01:24:35 PM »
replaced pump lines resi and cooler problem solved
wesley [OP]
  • Turtle Points: -1
« Reply #18 on: Apr 02, 2010, 11:30:45 PM »
turned out to be a bad box. unfortunately while i was climbing up on a cart (with wheels on it) at the local 4x4 shop to get my new/used box of a shelf... the cart rolled out and i ate it into a pile of parts. little blood and a few bruises. but hey, it all works now.
Last post Aug 17, 2005, 06:43:25 AM
by 88runner
Last post Dec 23, 2006, 05:01:31 PM
by 6.72:1
Last post May 27, 2008, 11:55:48 AM
by CTENG in KS
Last post Oct 27, 2010, 11:17:40 AM
by gnob
Last post Nov 01, 2018, 06:35:31 AM
by someirishjerk
