help with brakes
Started by shane87, March 08, 2010, 05:02:44 PM
shane87
brakes are getting hard when i go to stop the brake pedal is hard as :pokinit: and the way to brake them loose, is to loose the bleeder nut and then there fine for a little bit.... I replaced the master cycler and caliper's...
What could it be???
83yota5960
have the right brake fluid maybe drain it and put new fluid not sure though just throwin something out there. check brake lines?
83 short bed yota 35's 5.29's 4.7 f-150's arb front aussie locker rear high steer ifs rear axle
83 short bed yota 31 a/t mild lift welded ifs rear axle
99 audi A4 as my new daily driver.
shane87
wesley
maybe its the rear proportioning valve above the rear axle acting up. it adjusts the stiffness of the brakes by judging by the sag in the rear caused by a load. if its busted it might be causing your problem
69 cruiser
does your vehicle have a brake booster?  What vehicle is it
You got to build it to own it
SFD4x4
So your brakes are locking up and not releasing or is it just hard to apply the brakes or both?
83 pickup, 4.88s, chevys in rear, RUF, Dual Transfers, flat belly, 3RZ swap, disc brake x4, rollin on 36" irocs
IF YOU SEE A 20' PAC WEST/CARSON FLAT BED TRAILER FOR SALE CHECK OUT THE STOLEN SECTION.  IT MIGHT BE MINE!!!!
laskt9
yea i didnt understand that either
shane87
Quote from: SFD4x4 on March 15, 2010, 12:17:15 PM
its doing both...
shane87
Quote from: 69 cruiser on March 15, 2010, 11:43:57 AM
yes it has a brake booster and it's a 87 pickup ext cab with a 22re efi
YotaNate
If the pedal is extremely hard to push I would say check the vac line to the booster and the booster itself.  If the brakes are locking up and sticking is it the front or rears?  My wife's 86 Runner had a problem with the rear drums being so rusted the ebrake "arms" on the axle housing would not spring back when you released the parking break and the ass end would be locked up until you gave it Gas and popped the brakes loose a bit.  Needless to say she has all new brakes now.
Nate
"A CNN reporter, while interviewing a Marine Sniper asked.  What do you feel when you shoot a terrorist"?
The Marine shrugged and replied, "Recoil."
toyota sr5
Bad master, or wrong master. My 86 did this after I replaced my master the cylinder was the wrong one and it caused it to lock up like it had micro locks there is a valve inside that will slide all the way forward and not return thus locking the front brakes.
Yoda4x478
I had a similar problem with my rig. I replaced everything and could never get rid of it for good.
