REARS UP FRONT
Started by 85yotapolo, February 27, 2010, 09:32:04 AM
85yotapolo
OK WELL I STARTED MY REAR SWAP GOING TO DO CHEVY SPRINGS IN REAR... SO FAR GOT IT ALLL TORN DOWN AND WATING FOR MY KIT TO COME IN TODAY HOPEFULLY FROM SKY... ALSO ORDERED SPRING HANGER FOR FRONT...
MY QUESTIONS???
ON THE REARS STOCK SPRINGS IT HAS METAL BUSHING IN IT DO I HAVE TO TAKE THAT OUT TO PUT IN FRONT OR?
WHAT YOU GUYS THINK WHEN I WELD UP MY FRONT HANGER SHOULD I WELD IT 1 INCH FORWARD OR JUST WELD FLUSH???
runr-meech
I knocked those metal sleeves out with a socket.All that metal does is rust.
88 4runner
85yotapolo
sounds good man thankssss.... as far as the front spring hanger i think im going to weld in 1 inch forward....   what you think..
4x4yota
the further forward you fut it the less approach angle you will have and RUF move your axle 1.5" forward any ways I would go flush
Current:
Sold:
85yotapolo
TRUE THAT I THINK I'LL WELD IT FLUSH... I JUST HEARD PEOPLE WELD IT FORWARD DUE TO THE REAR SHACKLE NOT SITTING STRAIGHT IT SITS LEANING BACK.. I GUESS AT A NEGATIVE...
-Jake-
Quote from: 85yotapolo on February 28, 2010, 04:32:24 AM
you want it leaning back
85yotapolo
lol shows what i know....   ok so flush it is..
89sastoyo
don't weld it flush.. move it forwards about a half inch I would atleast. You can still accomplish a great shackle angle by using second or third gen rears. First gen rears are a little shorter. I have always welded hangers on a little forwards to keep the tires as far forwards as possible.Also not talking poop but moving the hanger forward changes the approach angle in no way. The springs he uses are the springs he uses its going to have the same approach if the hanger is 3ft forwards or two inches the distance from the centerpin the eye on the spring will be the same no matter what.
89 extra cab stock on 1 tons.
92 2wd DD
first gen cab
Check out the build.
85yotapolo
well i started the swap, waiting my sky hanger and flip kit to come in then i should finish up pretty quick.....
ok couple quick noob ???
on dr side spring perch it has 3 holes so i can move axle back little.... and my ??? is on passenger side the perch has only one hole... do i need to drill the same as dr side or?????
yea i know noob but want to get :pokinit: right the first time....
