Jon's 85 Runner...
Started by Gixxer Jon, February 01, 2010, 08:04:21 PM
Gixxer Jon
I got the ifs steering box in the mail today, already tapped for hydro. :woohoo:
I was waiting for some paint to dry, So I mounted the front blinkers out of the way Because I'm gonna build a tube front bumper soon.
Hillcrest Crawlers
_________________________________
||_________||_________||__TOYOTA_||
||_________||_________||__________||
http://board.marlincrawler.com/index.php?topic=67011.0
Jakesteads
i like your turn signals... im gonna do this
I like Toyota
Gixxer Jon
Quote from: Jakesteads on March 16, 2010, 10:26:19 AM
Bump, I took two extra seconds and make a backing plate bc i didnt want to do it half a$$ with zip ties
Hillcrest Crawlers
<MIKE>
1987 4runner
Dual cases, 2.28-4.7
Dana 60 Rear; Danna 44 front; 5.89's
249:1
Jakesteads
ya i see that hahaha i have no front turn signals and thats a perfect idea right there
I like Toyota
<MIKE>
1987 4runner
249:1
Gixxer Jon
Hillcrest Crawlers
83yota5960
83 short bed yota 35's 5.29's 4.7 f-150's arb front aussie locker rear high steer ifs rear axle
83 short bed yota 31 a/t mild lift welded ifs rear axle
99 audi A4 as my new daily driver.
<MIKE>
thats a nice looking box. at least i finally get to see what they look like now. i think i will buy one when he gets some more tapped.
1987 4runner
249:1
Gixxer Jon
Quote from: Tacosupreme on March 16, 2010, 11:27:13 PM
Its a second gen steer box.
Hillcrest Crawlers
<MIKE>
do you know if the mounting holes are the same between second and third gen boxes? if so i'll get one.
1987 4runner
249:1
Gixxer Jon
Hillcrest Crawlers
Gixxer Jon
Got the IFS box mount built & tacked into place this afternoon, I'll finish welding it up tomorrow.  :flamer: I moved it as far forward with out having to hack the S**t of the core support since i already hacked it crap load. (Don't think the beer helped any)  :smack:
Tomorrow, I'm going to brace the core support to give it back its strength since i hacked alot of it out since i dont have a body lift to minimize the amount cut out.
Hillcrest Crawlers
YotaNate
You sir are wrong!  Beer ALWAYS helps!   :beerchug:
Nate
"A CNN reporter, while interviewing a Marine Sniper asked.  What do you feel when you shoot a terrorist"?
The Marine shrugged and replied, "Recoil."
Gixxer Jon
Quote from: YotaNate on March 18, 2010, 08:48:10 AM
Nate
Very true, Very true..
Hillcrest Crawlers
Gixxer Jon
Finally got the mount welded in and steering box mounted..
Now i got to brace the core support.
Moved it pretty far forward.
Hillcrest Crawlers
Jakesteads
nice job dude did u have to lengthen your shaft?
I like Toyota
Gixxer Jon
Quote from: Jakesteads on March 18, 2010, 07:20:33 PM
I'm doing that as we speak, i had to extend it 2-5/8"
Hillcrest Crawlers
Jakesteads
did u drill out the pins or just box it
I like Toyota
Gixxer Jon
I extended the steering shaft 2-5/8", I used some 1-1/4" x 120 dom that i had laying around. The I.D. fit the steering shaft perfectly
:flamer: Gotta love tig welding...   :bowdown:
Hillcrest Crawlers
Gixxer Jon
:woohoo:  Got my front hangers for my rear springs and the front hangers for my front springs. so time to hang the 63's and move the front axle forward and drop the front brackets...
Got to love having a friend thats a machinist
Hillcrest Crawlers
Gixxer Jon
Got the front hanger fully welded up and boxed the ends. :flamer: Gonna move it forward an 1" from stock and it has a 2" drop.
Hillcrest Crawlers
Gixxer Jon
Got the front drop hanger welded up today, so I moved the front axle another 1" forward so a total of 3" for the front axle. and dropped the hanger mounts 2".
Hillcrest Crawlers
Volcom
Hanger looks good.  Just a heads up, you might want to box the front of the actual place where the springs bolt to the hanger.  If you were to hit just one side on a rock, you risk bending them up.
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
Gixxer Jon
Got the front end back on after installing 3" downey RUF, front Drop Hanger, boxed in the steering stops, removing torque rod brackets, installed the IFS box, lengthened the steering shaft, U- bolt flip kit.
Now im just waiting for my histeer to show up in the mail and got to finish my square d-line.
So i moved the front axle a total of 3" forward and dropped the front hanger 2". So i have a total suspension lift some where around 6" - 6-1/2"
Now its time to install the rear 63's..
It looks funny with the 33's that i have until i get new or used tires
Hillcrest Crawlers
RocklinCrawler
Gixxer Jon
Thanks, Shes in the middle of getting a whole new face lift....  :yupyup: Cant wait to wheel here and see the major difference.  :driving:
Hillcrest Crawlers
Gixxer Jon
Got the rear spring hangers welded in, Welded the hanger 10" eye to eye from the stock hanger to push my rear axle 1" rearward. Now I have a 107" WB. :woohoo:
Got the rear shock hoop made, after taking rear axle flex measurements, then i will place the shock mount bolts on the hoop in the proper place.
Hillcrest Crawlers
Gixxer Jon
Finished welding up the front square D-Line, now i just have to take some measurements and cut it to length.  :headscratch:
So since I'm running a double shackle set up & havn't seen anyone do this, I installed some (DELRUN) in between the frame rail and shackle to dampen the sound and the pressure when the second shackle cycles up and down...
I used Delrun because its a little softer then nylon but harder then UHMW cause UHMW is to soft...
Hillcrest Crawlers
superyota
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
