Running I.F.S.
Started by DirtyDan, May 14, 2003, 04:33:29 PM
DirtyDan
I don't have the money or the resources to doa S.A.S. right now and won't for a while. I was wondering if any of y'all wheel w/ IFS. I know it isn't common, but it is mt cituation. If you do run IFS, please tell me the necesary things to make it lkast...ohh...I don't know...past the trail head. I know I will need alot of CV's. pleaase help me w/ this. I know all about SAS but nothing about  IFS.   :help:                                                        -Dirty Dan
Kiss My Irish Ass ! ! !
#1
The best place to start your search is www.rockstomper.com they seem to be pretty good at keeping it together after one of their trucks made it into top truck challenge a couple of years ago!!
84runner
#2
I hear it can be done with I.F.S., so your not in that bad of shape. Just a little encouragement
mr4x42u
#3
Yea,,rockstomper.com has a great long travel set up for ifs that works pretty good..I mean its still ifs but at least with his set up its better..I run the stock ifs set up in my tacoma off road and it does fine..I beat the holy crap out of it..But then its just a beater any way and i just don't care...But out in the sand its a blast having that soft suspension..It don't hold a candle to my solid axle toy on the rocks..
shasharep
#4
a good friend and fellow wheeler runs a taco with old man emu stuff in it and I am really impressed, his rear flexes so well. the front does not have much travel but I do believe that AOR has the Total Chaos suspension available, but it is spendy, I have seen this set ip in action and it is impressive. something like 12 inches of travel in the front with T100 front CV's.... Just a thought.
Late Shaw
37's, detroits, longs, tube doors, stinger, Aw hell just look for a pic.......
#5
IFS would be great (of course independent wheel flex is ideal in theory) but one of the biggest concerns is that not only is it heavier than a live axle, but the majority of the weight is fully connected to the chassis and at a higher location. So the center of gravity is much much higher as compared to a live axle.
The live axle's weight is fully suspended by the tires, and below the springs, whereas the IFS the weight is bolted to the chassis. This is why live axles has a nicer ride over perpendicular objects and this is why the shocks always go out on IFS much faster than on Live axles.
Just to much weight to high up and connected to the frame. I think that if it did not have this drawback, then it would out wheel a live axle.
Regards,
mr4x42u
#6
yea,,I would love to have the total choas kit.right now i have the allpro front 2in spacers and those alone helped alot.I have a buddy that hasa t/c it in his tacoma.kicks ass.I am just not sure what I am going to do with my tacoma yet,,for now I'm just wheeling the piss out of it..I though about a motor transplant,(that was the orignal plan)but after getting it running,its alot of fun thrashing a 2000 tacoma..I have taken it too several races over the last couple of months and have taken first in 4 out of 5 with it in the 4cyl class..the one race they ran 4 and 6 together and i got beat by a supercharged v-6 tacoma...
snorklehead
#7
I still running IFS but I don't hit major rocks with it. I have some unlimited cv's and some spacers from rockstomper installed. Works pretty good but I am shooting for a SAS when I can afford it.
 :crazy:
The beatings will continue till morale improves
HFCRAOffroading
#8
I still run the stock IFS.  I lucked out a couple of years ago and got one of Drew's Idler Arms before he quit making them.  That was a life saver for me.  I was chewing up an arm a trip before hand.
  I also run lockers front and rear.  I carry spare CV's.  My biggest thing is I watch my front tires very carefully when on the trail so I don't crank the tires one way or the other full lock.   Any other questions go ahead and shoot me an email at
[email protected] and I will be more than happy to pass along anything that I have learned.
  Hope this helps.
       Jack
J.D.Zuki
#9
I just scored a 4 inch lift at pick-n-pull for 71$ :shocking: Its a trail master lift and i got all the goodies with it.So i think next year i may attend the round up with this lift :joke: :hahaha: :laugh:
I'm not tailgating,i'm trying to run over your honda.
snorklehead
#10
DANG....$71 good score. Even if you resold it you could get some cash out of it. I know a few guys looking for IFS lifts in TN.  :psss:  :thumb:
J.D.Zuki
#11
I kind of like it.All my friend talk so much s#@t about me running it. I think i might take it up to the round up next year. 8) Maybe a dual case and 35s :beer:
pjohnson
#12
I run IFS.....
Top of the Big Sluice on the Rubicon.
If you go to my site, the links don't work. No time to work on it.
Phil
J.D.Zuki
#13
Right on,thats what im talking about. :hahaha:
Terry4X4
#14
I ran my IFS pretty hard for 5 years before it finally gave out.  During that time I never broke a CV or axle shaft.   It had an EZ locker in the front and a Softlocker in the rear.  Also had an Ultimate Marlin dual case setup w/4.56's and 33" BFG's.  To reduce wear on the front end I'd run the easy stuff in 2WD lo.  Also, in the knarly stuff my first choice was to finesse it.  Never tried to force anything.
You can wheel IFS pretty hard but after awhile it will begin to break down.  I ended up doing a SAS this year more so for reliablilty than anything else.
For me IFS problematic parts were Idler Arms and the front crossmember bracket that bolts through your front diff.
Terry Johnson
President
Gettin' Off 4X4 Club
wheeloverhondas
#15
awhile back I almost got an ifs truck, i was thinking of going to the junk yard and getting the ifs out of a t-100(because there so much wider than a normal toy) and make my own axle shafts and using the t-100 ifs for a longer travel and to make it wider, it would take some fabing skills, but it would be cheap, and nabe flexy?
 but it would be stronger if you did it right!
  I want someone to try it!!, if not i will some day  :laugh:
87 xj, dana44/60, welded front and rear,hysteer being made,38s,and lots more
J.D.Zuki
#16
I think i'll try that after the dual case goes in. :~~:
rEdnECkwHeE1eR
#17
QuoteI think i'll try that after the dual case goes in. :~~:
So you're wheelina IFS truck now? What happend to the Zuki? Are you coming up to Fordice with Ryan and Over-rev for our club run? :chug:
Liquor up front
Poker in the rear
J.D.Zuki
Still have the zuki.Just put toy axles under it.And getting ready to put a toy dual case in it. :flamer:
94MtnYote
 Dumb question: will T100 cv's fit on stock ifs?  yeah It's wider but I thought maybe......
Marlin 1200LB clutch
NorCalToy
Quote from: 94DILUX on November 14, 2008, 12:14:10 PM
gonna say no, if you run the Total Chaos long travel kit you run em to keep four wheel drie and those arms extend you to 3" wider per side. so each T100 axle is 3" longer than a mini truck IFS
:flamer: IFS
5 years later.........
blackdog wheels ifs, and he beats on it too.....
94MtnYote
Quote from: jimbo74 on November 14, 2008, 06:56:59 PM
yes and a fine relic it is...
Birfailed
IFS is fun if your 16 and scored some Natty's from your buddy's older brother and your on summer break.  That's what IFS meant to me back then.
Go 1-Ton from the start
JohnHalladay
I got Stock toyota ifs on my 88 pickup. with a rough 3 inch body and 2 inch shakle in the rear and cranked torrison bars in front. Im running 35 12.5 swampers with 2 inch wheel spacers and it goes places! i think ifs is strong or at least mine.... cause i rail the S**T out of it and it still gets me to work every day after! lol
yota pu/runner
i'll agree i had a 95 runner with a 2" body and Old Man Emu coils in the rear on 33" no lockers no gears or anything. it took a few tries on some stuff but i could make it through anything that my buddy did and he has a Cherokee on 33", but he does drive a jeep after all. :rofl2:
Goose
hey, i wheeled ifs for a couple years before i got my sas together and done..
all i had was a welded rear, (and front later on) some aftermarket torsion bars, warn hubs, and some 33" bfg mud terrains..
with ifs, its all slow goin and finesse. i learned that the hard way. I broke a total of 5 CV joints...
i even did the roundup in 07.
sliders are a must, along with a rear locker and lots of practice.
One cool thing about ifs is, if you wheel with it, youll and learn how to pick your lines carefully, then when you get a solid axle, driving through obstacles seems so much easier...
Baller Status: Coming Soon To A Toyota Near You!...   :afro:
My Life Is A Very Complicated Drinking Game... -Me
90 ext. cab v6, SAS'd, 37's
94 4runner -work in progress
www.slagfactory.com
My Buildups:
'90 ext. cab
http://board.marlincrawler.com/index.php?topic=38260.new#new
'94 4Runner
http://board.marlincrawler.com/index.php?topic=53882.new#new
BLACKDOG
Quote from: Goose on November 26, 2008, 03:47:04 PM
:werd: and get comfortable with only 3 wheels on the ground :gap:  Makes for some cool pictures with little effort though! :hahaha:
              -Ronald Reagan
yota pu/runner
Yeah i will second that going from IFS to solid axle i am a way better driver for it.  i did enjoy my IFS but i love my solid axle.  and that is also true you do get some cool pics with the IFS sometimes.
Um, yeah IFS really sucks I'd be skeerd to climb a speed bump at the mall with an IFS truck.
