1989 extra cab SAS 3.4 swap
Started by johnny916, December 29, 2009, 02:24:31 PM
johnny916
tax time is here must let it go.I've own this truck for 10 years and just did a 3.4 swap in it now.There are a few things that still needs to be finish.like shock hoops needs to be welded,radiator and high steer.
truck has a 2000 3.4L,daul transfercase, 2.28 in front and 4.7 in rear(new gears and adapters)motor is droped down 2 inch to clear super charge if you want to put one on it,moved 2 inch forward so the cross over pipe wouldn't be so close to the fire wall.steering box is moved forward. I hate to sale it but I need the money to pay my tax.
              Truck is a 89extra cab sr5 model with power every thing with sunroof   located in
    v6 third with 529 detroit (new)        Elk Grove/Sacramento
   4cy third with 529 lock right (new)
  2- 5150 (new) 14 inch
  2- 5125 (new) 14 inch
ORS wire hardness (new)
chromo. inner shaft and birf. (new)  4.7 gears and adapter(new) twin stick (used)
fade
86 mini truck 18" rays
09 highlander
70 suburban
johnny916
rockcrawlinredneck
Has it been through the ref. yet? Smog legal swap?
fade
Doesnt even look like its got a air filter in the pictures or even a box so I doubt its smogged. On 2nd look it does'nt even have a radiator in it either. Does this truck run even?
09 highlander
70 suburban
johnny916
yes it does run and no it has not gone through the fer. yet. If some one wants me to take care
all that, it would be more $$$.
86moneypit
does it run and all the wiring hooked up just finishing touches to motor left
what lift is on it
86 Runner 529s locked duals 37s
96 Runner 5sp. 3.4 32s DD
04.5 Dodge 2500 CTD With Go Fast Stuff On It
Drive it like you stole it
johnny916
the only thing not hooked up is 02 sensor.but it wll run with out it. I can put it on the lift and run it so that you can see that it run, I can't just steer because there is no high steer.
johnny916
some one buy it, I need to come up with $10k for my tax.
axled89
is that the lift. 14" 5150-5125  ???
i love oregon wheelin.
yota_krawler
bump for a cool rig, just needs a few things. i went and saw it when I got the axles im runnin.
crawlerbubba
lookin 4 any trades,or strictly cash?
GOT ROCKS?
fade
Quote from: axled89 on January 04, 2010, 04:18:17 PM
shocks are 14" 5150 are the fronts with external res, 5125 are internals.
09 highlander
70 suburban
johnny916
The only truck I would trade for a 2000 up F250 quad cab 4x4 DIESEL.
