runr-meech's 88 build
Started by runr-meech, December 28, 2009, 09:13:56 PM
86bobbedtoy
runr-meech
thanks Heath , Twisted. got my fingers crossed!
88 4runner
runr-meech
no news on my engine yet. :sad2:  but UPS kicked down for my wifes pathfinder,  and she is just going to throw a new door on and we're gettin a 2005 Toyota Tundra.  :biggthumpup:
88 4runner
P-DiseToy24
Nice on the tundra Mitch...
Im gunna be in town in a couple days and can finally pull that exhaust if you still want it.??
runr-meech
KC, yea i still want that exhaust, call me when you get into town.
88 4runner
P-DiseToy24
got some of it pulled when I was there but had NO time for anything sorry man let me see what i can do as far and gettin someone to unbolt the rest for you.
runr-meech
#216
Trying to get my rig going today so i can wheel for new years! Got oil pressure for a minute after i primed my new oil pump, going to try a few more times to see if that has been my problem. Cross your fingers!
88 4runner
Dingman.
Get it done for some wheelin!!!!
twistedtoy92
runr-meech
got oil pressure for minute, then none. Repeated and had oil pressure for for a minute or so then no pressure. I'm thinking bad new oil pump..? Any other ideas????
88 4runner
santa cruz crawler
X2 on the oil pump
Sorry to hear.
runr-meech
Well only way to find out is drain the oil and tear it down again, talked to Putney this morning and hes said it could only be a few different things and a bad oil pump is one of them. So oil is draining and i'll start at the bottom.
88 4runner
86bobbedtoy
well you have used all ur bad luck.
.hopefully you got some good coming up
keep us informed
runr-meech
well its just about all apart, going to pick up a new oil pump in the mornin.
88 4runner
86bobbedtoy
runr-meech
OH, im kicking myself!!!!! talked to Putney last night for awhile trying to find out why i have no oil pressure. When he says did you put back the bottom plug right inside the oil pan? I said what plug, i never took that plug out,  he says i did. SH#T! all this time and all it was , was a little friggen plug! Well off to buy more oil and put her back together and hope i didn't screw up the top end.
88 4runner
runr-meech
Well , that was the problem. after ripping this thing apart three times its a stupid plug that i didnt even know was missing!running allright , off to get a new alt. and a new battery.
88 4runner
86bobbedtoy
well awesome, kinda, sucks you did all that.
hows she run?
runr-meech
runs good , alittle knock in the top but Putney said he would take care of it for me. Going to put a few more things on her and take her for a run.
88 4runner
86bobbedtoy
Dingman.
I think he said it had something to do with the cam
runr-meech
#231
I think its one of my cam caps, but could be a valve adj.
88 4runner
twistedtoy92
Quote from: twistedtoy92 on December 01, 2010, 08:55:52 PM
missing oil galley plug inside the block? or you have a bad oil pressure sending unit.... Put a manual gauge on it and see what kind of pressures you are REALLY getting!
I figured...... at least you found it!
runr-meech
Well did a few tests at Tony's shop and discovered that i have a bad bearing in #1 cylinder, so its a rod or a main, so im just going to replace both of em.Hope this is it with this engine for a while!
88 4runner
86bobbedtoy
holly fu$k
do you always have bad luck,
just do all the mains and rods while you are there
I always used federal moogal (MOOG)
so what did putney even do to the motor?
Thomas P
'14 Camry SE
SCX10 Honcho on roids!
runr-meech
Heads fine. And yea i have 0 luck with motors in this truck.I have been using King bearings but going to try suppin different this round. I have a plug elim. on #1 cylinder and it runs  :boobs: no knocks, sounds great!
88 4runner
86bobbedtoy
runr-meech
got my new parts, hope i finnish her before i have to go to school at 6!
88 4runner
runr-meech
FINALLY!  I got her running  :boobs: ! New Runr !  :clap2: :clap2: :clap2: :clap2: :clap2: :clap2: :clap2: :clap2: :willynilly: :willynilly: :willynilly: :willynilly:
   Oh yea went to High Angle and ordered my new front driveline also, it'll be done Mon. mornin.  :willynilly: :willynilly: :beerchug: :beerchug: :beerchug: :beerchug:
88 4runner
