Put a jumper wire in the fuel-pump test connector.This will turn the pump on when the ignition is on, pressurizing the system before you start cranking.If that solves the problem, you're losing pressure when it sits.
I always thought about that because when i turn the ignition on, I dont hear any noises from fuel pump. and I can see it thru my floor because of my missing inspection plate. But lately its been startin up really easy in the 15 degree mornings.
Started by toyotaboy General 4WD Discussion
Started by WileEToyote Engine
Started by mudmaster « 1 2 » Engine
Started by toymech Toyota Pickup/4Runner Tech 1979-95
Started by miks85yota Engine
