maybe a wire is shortin out but iv had that happin to its scary
would a loose belt make it do that?
check the alternator plug and the belt tension. I dont think the belt would make it shut off but it wouldnt hurt. Sounds like a ground most likely..but i dont know
i checked out my grounds today and couldnt find anything wrong.. i have 2 grounds off my battery.. one to the block and one to the driver side fender right next to the battery. none to the frame... maybe i need to add one to the frame and get rid of the one going to the inner fender
if grounds are good and clean start checking posative cable especially at the fuse block.
check the 30amp and 40amp fuses in the fuse box they will be the big ones. also did you get any mud or water in the alt. that will cook a alt fast.
