"GENERAL LEE" New toy for winter
Started by yotaneck13, November 13, 2009, 04:32:37 PM
yotaneck13
lol everytime i try to resize it distorts my pics  today i got almost all of the ifs brackets cut off and 4RUNNER is trading me his 83 front axel for my 22re and tranny and a bunch of other parts so now all i need is hi steer and a rebuild kit for the new power
yotaneck13
ok so i need to get my hi steer ordered so i have it when needed but i dont kno wether to order a flat or drop pitman arm ( I AM GETTING A TG KIT FOR NOW...I DONT HAVE THE CASH FOR THE MARLIN THAT I WANT SO IM ORDERING OFF EBAY BUT WILL BE REPLACED AS SOON AS I HAVE FUNDS FOR A MARLIN) now with that said im going to go with about a 6 leaf ruf pack with the over load removed and a stock or slightly longer shakel can anyone give me some imput on the arm i should choose ??? :help:
yotaneck13
peacesells
Youre gonna regret buyin the tg kit.. I bought that kit and after 4k miles had to replace all of the rod ends. Also, the arms arent designed properly and put much more stress on the steering studs. It cost me twice as much to buy the cheap parts first...
If you must buy trail jizz parts, get the flat if you are doing very little lift, get the drop if you are doing 4in or more. I run a sky 3/4 drop arm with 3in lift and it works great.
this my man lysol, fresh out the joint
spc mike
Quote from: peacesells on March 13, 2011, 10:37:36 PM
So the Marlin arms are geometrically a lot different that the TG ones? Have you broken any studs with the TG Arms?
Sparkplug
taper is supposedly different, causing cones to not seat all way, thus not fully thightening, All makers of high steer arms claim to have the "CORRECT" geometry vs the compettition, so I dont know about either one being better, I own both, and I like marlins, but only cause it billet.
peacesells
I have never broken a stud, but I have always run arp's and never abused this truck when it had the TG kit. Everyone that I know who has sheared or ripped the threads out of the knuckle has been running TG arms. Ive seen marlins, 4x4labs, and allpros take abuse with much better results.
Sparkplug is correct, the tg's have an odd taper where the cone washers only seat on about 1/16in surface. Marlins arms are more like the stock toyota taper. The bigger concern to me is how high up on the studs the cone washers seat on TG arms. There is somewhere around 3/4 of an inch, that space turns into leverage twisting on the studs. Thats also what contributes to the TG arms constantly coming loose with bigger tires. The stock toy arms seat the cone washer about 1/4 inch (dont take this as fact, its been a while since I did the comparison) up on the stud.
yotaneck13
well im not getn the tg kit now ill have my own custome steering for now till i can afford marlin or 4x4 labs
Sparkplug
On a side note, im replacing 2 KNUCKLES on my 4runner today, I have arp studs, and marlin arms. 1 knuckle has 2 stripped stud holes, the other has 1, refuse to torque past 30 lbs. I am nototrious about checking torque. I have about had it with toyota knuckles and steering in general. I only run 36 inch tires, and I havent even hit much rocks, and already have been plagued by horrible issues with truns, knuckles, studs, and general steering
yotaneck13
peacesells
You gotta make sure youre starting with knuckles that are in perfect shape, most of them are not... Both sets ive owned were, I have arp's and torque to 100 ft lbs and check them regularly. Never had a problem on 37's now and 40's in the past.
yotaneck13
got my frame all cleaned up and primered back to the front gastank cross member gonna fix a few spots and gusset tomorro and possibly move my steering box foward as far as it will go
yotaneck13
ok tonight i got my steering box moved foward and mountel it looks pretty good i think
here is the brackets i made to hole the box
and here is the box mounted
Muddytazz
Looks good from what I can tell.  Anyway to post some bigger pics?
Build it right or get off the trail
yotaneck13
ive tried i even resized these ones on photobucket and they still come out small any sugestions?
yotaneck13
Peterbuilt84
Most likely, pics are going to be small off of a phone.
yotaneck13
yotaneck13
ok tonight i got my steering box reloction buttoned up and the body mount boxed in where i had to cut it out and my top gussets done on the frame  heres some pics
steering relocation
anothe of the relocation and bod mount boxed in
and one from the top
here is the passenger sidefront gusset on the top of the frame
and the drivers side front gusset on the top of the frame
for only being in the shop for 2.5 hours i think i got a lot accomplished and am happy with how everything came out
87hillbillyoter
1987 SAS'ed toyota 4x4 pickup 22re swap
build up- http://board.marlincrawler.com/index.php?topic=75111.0
yotaneck13
neither can i  i should have the frame done and ready to build the spring hangers by tm night i need to pach part of the frameby the gastank and gusset the back and everyxmember will have gussets top and bottom be stron as all hell
4runner
lookin good  gonna have to get the axle to ya tomorrow
that'll keep ya motivated
built not bought 89 4runner
vortec v8, r151, dual cases
4link 1/4 elliptical
yotaneck13
for sureit will i need to tear it down to put my t100 breaks and ifs hubs on it anyways maybe weld spyders till i get a locker
yotaneck13
i wanna get the back portion of the frame cearned up patched and gusseted by the end of today and ill be hapy
yotaneck13
FRANKENYOTA91
85 toy double extended cab pos wheeler bobby longs, welded front and rear, dual cases
89 4runner sas,  duals, the usual
81 toyota long box project
83 short box project
2001 Cummins 6 speed tow rig
yotaneck13
Thanks i got  the back half of the frame grinded down to bare metal this afternoon and both inside rails are pretty much junk imgoing to be cutting them out and patching in new pieces later tonight
yotaneck13
got the back half of the frame completly to bare metal tonight removed front 2 bed mounts and back cab mount as it will need to be moved back for the ex cab and made templates to cut the patch pieces out for my frame tm ill cut them out of metal and weld in and then fnish primering the frame then is on to drilling the holes in the frame for my tubes which are made (thanks to 4runner) as 1.75 dom boared out about an 8th inch to the correct size of the bushing  ill weld thoes in and start making my front spring hanger
