your wondering if the shaft is out of phase, go look and see
Do you have a CV joint in the front of the d-line? And the pinion must be pointing to the t-case output. Is it possible that the d-line is out of balance, or slightly bent?
why did you mount the f150's backwards??
So you don't have a huge over hang
you need to have a cv joint at the t case side, do you have one of the two piece driveshafts? if so thats definetly your problem, get a one piece with a cv.
i didnt need a cv , and its only got a slight vibration at 80 mph or more
did the axle move back? maybe the slip splines are almost pulled apart
you have a one peice drive shaft dont you?, with a two peice you need to change it, with a one piece you probably wont.
Started by SLIVER Toyota Pickup/4Runner Tech 1979-95
Started by 89toy « 1 2 » Toyota Pickup/4Runner Tech 1979-95
Started by Aaronm Parts For Sale
Started by FLRunner 1984-1988: How-To Guides
Started by Thomas P Parts Wanted
