Broken Studs
Started by 86toyota, October 20, 2009, 09:02:26 PM
86toyota
Today 4 of my wheel studs that hold the wheel spacer on randomly broke...4!! Has this happened to any body else? Not the wide 2"+ ones either. The ones that come with the Marlin SAS kit.  :smack:
T86OTA
Cheesemaker
Can you get pics of the broken studs?  Good pics.
Alot of times, studs will break for several reasons.  Over/under torqued.  Old and weak studs.
Did you put some loctite on them when installed?  And periodically check them with a torque wrench.  This is the one downside of running spacers, but with some checking from time to time, you shouldn't have any problems.
86toyota
#2
No i alrieady thru them away. I did torque them to spec with locktite the summer of 08 when i did the SAS but no, i failed to check torque since then over time. Also one more question. Wrong thread, i know, But im new to the forum and cant figure out how to add my own picture to my profile. help?  :confused:
T86OTA
Steve_925
you need 12 posts i think to get an advatar and post pics.
UA 342
STEAMFITTERS
86toyota
T86OTA
boggerunner
u can buy new studs for them, big o sells them, my buddy had 3 broken studs and replaced them for less that $10
Dollars to donuts they were loose since you broke 4  ;)  It pays to be anal about vehicle maintenance, especially when a vehicle sees heavy or extreme use.  I work at a busy tire shop and even if we just change 1 tire on a rig we check torque on all 4, and it's not at all uncommon to come across a few loose lugs.
emsvitil
Once 1 went, you probably got a domino effect..............
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Bazzi
Quote from: kneedownnate on October 21, 2009, 12:16:13 AM
do you allways tighten the wheels on the trucks with a tourqe wrench or do you just tighen it with an air gun?
2,4 dti duals 2,28 x 2,28 to 8" 5.71 with arbĀ“s  and 39,5" trxus
86toyota
Yeah thats what i figured is the domino effect. If im at my dads shop i tighten them down with an air gun and torque stick. If im at my house i use a torque wrench. I know how to change them but i was on my way over to tire rama at the time they broke so im just having them do them since they have to do an alignment and check the balance on my tires.
T86OTA
axled89
my studs have broke after i hit a ditch pretty hard.   then driving it down the road the wheel came off due to the wheel being bent. :cool:
i love oregon wheelin.
BUDDERS
Your torque wrench might need calibration too.  If it's off, you could have gotten them too tight or too loose....
Volcom
What do you guys consider too tight?  I usually torque all the lugs (spacers included) at 90 ft/lbs.
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
BUDDERS
I was taught to torque the 21mm lugs to 75 ft-lbs.  I'm sure that's not the factory spec, but it's pretty close and I've never broken one or lost a wheel.  The 22mm lugs on the newer 5 lug cruisers and Tundras are more (around 100 ft-lbs I think).
86toyota
I thought alignment and getting my tires balanced would fix my vibration but i was wrong. I still have a vibration from 40-55 mph then after 75. There is no play in my aftermarket d-shaft. any ideas?
T86OTA
axled89
damn man i would of thought that would fix that problem.     :dunno:
86toyota
Yeah me to!! And it hasnt been like that since my SAS. It only started about 2 months ago. Maybe my rear diff? I dont think that would be it tho since it stops at 55 then starts again at 75.
T86OTA
axled89
maybe tie rods or steering stabilizer. :dunno:
86toyota
I dont think it could be steering stabalizer. mayber tire rods...but what about them? What can go wrong with them to cause vibration?
T86OTA
Cheesemaker
How's the wear on the tires?
How's the front end bearings?  Jack it up and check all the bearings yourself.  The trunion bearings and hub bearings.  Most alignment shops should check all the bearings for play before doing an alignment.
86toyota
the inside of the tire wore pretty good. When i was coming down the mountain after hunting last weekend i was hearing a clunk in the drivers side of the front axle so i knew that was a bearing. Tore it apart and the bearing was fine it was just a little loose. The bearing tension nut got loosened up so reset that to torque and got everything back together. WHen I had it apart I didnt pay attention to see if the wheel spacer was coming loose but then a few days later is when the studs broke on the way to the tire shop. It all happens at once with my pickup i swear.
T86OTA
Quote from: Bazzi on October 21, 2009, 03:59:22 AM
Always, ALWAYS with a torque wrench  ;)  We only snug them with the air gun using a torque stick, which limits the amount of torque transfered to the nuts.  The sequence we use is to run the lugs all the way down so the wheel sits flush against the hub in a star pattern, snug each lug again for a couple seconds, drop the rig so the wheels touch the ground, torque the lugs with the torque wrench in a star pattern, then double check torque in a circular motion to assure you didn't miss any.  I wonder how many lugs I tighten or loosen in the course of a day  :headscratch:
Oh, and the vast majority of Toyotas torque to 80-85 lbs  :thumbs:
BUDDERS
Yeah Nate, I use a 75 ft-lb torque stick on my 1/2" impact and then the torque wrench.  I like to make sure those things are on.  I've seen the damage from wheels flying off and I don't want to be the one responsible for that.
86toyota
Yeah my dads shop that he had had the same policy. Some one would go around torque them and then somebody else would have to go around and double torque them and both people would have to sign off on it. This eleminated many problems and was a nice safety cushion as far as liability goes.
T86OTA
Cheesemaker
When I have my rigs worked on at the tire shop, I make them run the lugnuts on by hand.  NO airgun!!  Especially, when they don't use torque sticks.  :shake_head:  I want to hear them work the torque wrench a couple of times before they click.
They think I'm an :moon:, but I know that my wheels aren't gonna fall off.
86toyota
Yeah i cant blame you there. Torque sticks arent that expensive not use for a tire shop. You gotta look at it from a buisness standpoint and that time is money. But just using an airgun with not torque sticks is just retarded!
T86OTA
illinoisyotadriver
 x 2 on torque stick my neighborhood tire shop hate me for that because i make them tighten them by hand  :burnout:
I've made tire shops do it by hand and they didn't make a fuss, and we sometimes get somebody in who wants them done entirely by hand.  No biggie, they just need to understand that it takes longer  ;)
