Some of the guys & one girl I run with!!
Those are both cool. Nice bed on the black one. What's with the 5 shifters?
dual case's 1 w/twin stick. rear shifter=front digs
Front digs with Toy cases ? Please elaborate.
It's a mechanical rear driveshaft disconnect that mounts to the tail housing of the rear t case.When you shift the lever forward(that zinc coated? tab on left) it disengages the rear driveshaft from t case output.
what's the purpose? why have it?
So you can do burn turns for one, with the rear driveshaft disengaged and park brake set, you can turn on a dime with just the front wheels turning. Works great if you're in a tight spot and don't want to or can't back up like on a steep climb and say your front end just slid out of the the line you were trying to run. Also, if you're getting to vertical on a climb and your front tires start lifting off the rocks, you can do the same to help pull the front back down. With the rear disconnected and locked, the front wheels will hunt for traction and "dig" your tuck back into the obstacle.
are you in TX? i think i know this trail........ is it sunday cruse at gilmer
I think it was Glenn? or Greg's Ravine maybe but yes it's at Barnwell Mtn. in Gilmer.
Started by NWyoat Trail Reports, Events, and Gatherings
Started by Dark Chaos « 1 2 » Chit Chat Camp
Started by Brandon Rigs For Sale
Started by 83yota Chit Chat Camp
Started by Makohon Project Research and Build-Ups
