Recipient vehicle:
1986 4X4, Xtra Cab, 22RT-E.
Donor Vehicle
1994 4X4 extended cab 22R-E
I know the optimum set up would be the R151, but those seem to be impossible to find and this donor truck has not been parted yet, so I can get all the parts.
So it should be a W56-E. I don't know if it has the gear or chain drive transfer.
I don't know what the differences between a forward shift and non forward shift are.
Will the cross member, pedals, and drive shafts work on the recipient '86 Xtra cab or is the frame different?
Will I have to modify the shifter to clear the pocket under the radio on the '86?
I want to double check my checklist as I will only get one shot at this.
Transmission from flywheel to end of transfer case
Pedals
Slave
Master
Hydraulic lines
Clutch cancel switch
Harness pieces for the back up lights
Transmission cross member
Anything else?
Thank you all very much for the help.
Dave
