Author Topic: OBD II Code Reader/Tester  (Read 4650 times)
Redboar
  • Turtle Points: -1
  • Member since Feb '07
« on: Sep 15, 2009, 05:39:10 PM »
Hi,
Looking for recommendations on what you think would be a good
OBD II code reader/tester to purchase.
Re: OBD II Code Reader/Tester
« Reply #1 on: Sep 15, 2009, 06:16:51 PM »
:dunno:
i know you can buy them at parts houses, but most parts houses will read the codes for free
88_Pathy
  • Turtle Points: 65
  • Male Posts: 1,251
  • Raised suspension
« Reply #2 on: Sep 15, 2009, 11:55:55 PM »
Scan Gauge 2 is the best for the money
Redboar [OP]
  • Turtle Points: -1
« Reply #3 on: Sep 16, 2009, 05:41:48 PM »
Thanks for the replies.
I should have been more specific.
I am looking to do an engine swap and I want to be able to take
it along and check a vehicle before I buy it and to use for diagnosing after
the swap is done.
  • Turtle Points: 7571
  • Male Posts: 3,561
    • emsvitil's album
« Reply #4 on: Sep 16, 2009, 10:42:39 PM »
If you only need to read the codes, you can get them cheap at Harbor Freight.
  • Turtle Points: 2872
  • Male Posts: 8,707
« Reply #5 on: Sep 16, 2009, 10:56:14 PM »
i got one off of ebay for $35 shipped
a decent one is the innova i think 3100 model, costs a bit more though
  • Turtle Points: 2159
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
« Reply #6 on: Sep 17, 2009, 01:27:20 PM »
If you have a laptop or computer with a long USB cable, then I HIGHLY recommend
http://www.obddiagnostics.com
Here are some examples of it in use in my build-up thread, Reply #565:
http://board.marlincrawler.com/index.php?topic=4401.msg55098#msg55098
Only about ~$80 and I've used it on over 20 different vehicles now. I love how easy it is to use, and I can immediately take screen shots and save everything to my computer including full simulation data.
Redboar [OP]
  • Turtle Points: -1
« Reply #7 on: Sep 17, 2009, 08:04:12 PM »
I will check those out.
Thanks for the info.     :biggthumpup:
PhantomD aka Zach
  • Male Posts: 210
  • Member since Jun '09
  • Needs more garage space!
« Reply #8 on: Sep 20, 2009, 11:54:22 PM »
I 2nd the ScanGauge II... I had some issues with some gauges not working on my engine swap when I owned a jeep. it helped me out tremendously... although it will only give you the code and not the meaning...
-Zach
3rd Gen Extra Cab, Dual Cases, E-Lockers
calitaco
  • Member since Aug '06
« Reply #9 on: Sep 22, 2009, 09:28:45 AM »
Costco has a decent portable OBDII scanner for $36.  It's a little handheld unit that's powered by the OBDII socket.
88_Pathy
  • Turtle Points: 65
  • Male Posts: 1,251
  • Raised suspension
« Reply #10 on: Sep 22, 2009, 11:10:09 AM »
The scan gauge will also monitor the sensors and read them on the screen in real time.
TIMS89CRAWLER
  • Turtle Points: 35
  • Male Posts: 1,968
  • Member since Oct '07
  • BORN TO WHEEL, FORCED TO WORK...
« Reply #11 on: Sep 22, 2009, 11:22:53 AM »
I own both a scangauge 2 as well as an autoTap... both work great however I like the scangauge 2 more as its small and portable and I can take it with me and use it as gauges....
www.choptechfab.com
www.myspace.com/choptechfab
CHECK THE BUILD
Redboar [OP]
  • Turtle Points: -1
« Reply #12 on: Sep 23, 2009, 05:43:13 PM »
A couple of questions on the ScanGaugeII.
Are there any other wires required to be hooked up besides the OBDII?
On the miles left to a tank of fuel, is there a way to gallons of fuel that the
tank holds?
Thanks.
88_Pathy
  • Turtle Points: 65
  • Male Posts: 1,251
  • Raised suspension
« Reply #13 on: Sep 23, 2009, 11:09:02 PM »
No, the port only.
If you program it that way it will estimate how much is left.  Mine is in the truck all the time and it is cool to see open and closed loop, or throttle position at any give time.
Redboar [OP]
  • Turtle Points: -1
« Reply #14 on: Sep 24, 2009, 05:15:48 PM »
Last post Aug 17, 2005, 06:43:25 AM
by 88runner
Last post Dec 05, 2011, 04:11:46 PM
by yotaneck13
Last post Jul 28, 2016, 07:29:20 PM
by haleyporter0939
Last post Jul 08, 2014, 01:00:43 PM
by toyotajoe
Last post Sep 01, 2020, 02:10:12 PM
by RUGER
