Author Topic: Please Help - What is This? 1982 22R  (Read 4571 times)
i_luv_my_truck
  • Turtle Points: -48
  • Male Posts: 157
  • Member since Mar '05
  • Toyota Crawler
    • My Rig
« on: Aug 20, 2009, 04:02:40 PM »
Please help, 1982 Toyota 22R.  What is This?
Thanks in advance,
1977 Toyota Hilux 2wd - because because
1980 Toyota Hilux 4x4 - restoration project
1981 Toyota Trekker - nostalgia
1982 Toyota Hilux 4X4 LB - just because
1984 Toyota Hilux 4X4 - everyday driver
2001 Toyota MR2 Spyder - for speed
1993 Toyota Previa - for relaxing
http://www.cardomain.com/ride/2093325/
ninja turtle
  • Turtle Points: 38
  • Male Posts: 1,072
  • Member since Sep '07
Re: Please Help - What is This? 1982 22R
« Reply #1 on: Aug 20, 2009, 04:05:42 PM »
oil pressure sending unit
i_luv_my_truck [OP]
  • Male Posts: 157
  • Toyota Crawler
    • My Rig
« Reply #2 on: Aug 20, 2009, 04:11:47 PM »
is'nt the oil pressure sending unit the small one, just on the top left?  my other 22R does'nt have this.
84solidaxletoy
  • Turtle Points: -3
  • Member since Aug '07
« Reply #3 on: Aug 20, 2009, 04:18:28 PM »
no, what you pointed in your picture is the oil pressure sending unit. the reason you don't have it on your other 22r is probably because it has the check oil dummy light.
i_luv_my_truck [OP]
  • Male Posts: 157
  • Toyota Crawler
    • My Rig
« Reply #4 on: Aug 20, 2009, 04:26:20 PM »
Thanks for the response,  So this vehicle has two oil sending units?  What would be the smaller one, just on the top left.
Caboose
  • Turtle Points: 62
  • Male Posts: 733
  • Member since Jan '05
  • Truth... Justice... Honor...
« Reply #5 on: Aug 20, 2009, 05:26:06 PM »
I think the big one is the oil pressure for the gauge and the other is the one for the idiot light.  At least when i ordered mine from napa they asked which one i wanted.
"Who let the jeeps come?
81 Toy Pickup SR5
Ruari
  • Male Posts: 153
  • Member since Sep '02
« Reply #6 on: Aug 21, 2009, 06:13:33 AM »
The part you have circled is the oil pressure sending unit for an SR5 dash cluster.  Non SR5's have a smaller sending unit that is basically an on off switch for the low oil pressure idiot light.  Either one screws into the block in the same location.  Having never owned an 82 I am not sure what the small part is to the left of the oil filter.  Best of luck to you.   :beerchug:
Ruari Legg
'84 X-TRA cab, 5.29 Front F-J80 high pinion e-locker/5.29 rear Tacoma e-locker, R.O.R.E. e-locker skid plates, MC dual t-case #480, MC 4.70 gears #1755, Budbuilt crossmember, MC crossover steering, Howe hydro-assist steering, Alcan springs with Orbit Eyes, FRORF full floater, TRD cam, LC Engineering adjustable cam gear, distributer, solid steel engine mounts, longfields, 35"x13.5 BFG Krawlers.
drayday55
  • Turtle Points: -1
  • Male Posts: 299
  • Member since Feb '09
« Reply #7 on: Aug 24, 2009, 03:12:09 PM »
if its in the oil passage its anothr sender of some sort, i know my knock sensor is at that spot on my 85 but i dont think carb motors have a knock sensor.
83MT
  • Turtle Points: -23
  • Member since Jun '08
« Reply #8 on: Aug 26, 2009, 11:55:26 AM »
Just as others have mentioned...big one (circled) is the oil pressure sending unit. Small one is the oil pressure switch. First gens have two instrument clusters. The main cluster has the oil idiot light and if you have a base model that's all you'll have. If you have a nicer model you'll have the separate oil & volt cluster. If you have both these, the idiot light and the pressure gauge, you'll have a separate sending unit for each.
Zach
I like Yotatech
Ruari
  • Male Posts: 153
« Reply #9 on: Sep 02, 2009, 01:26:06 PM »
Thanks for the handy information.... slide that one in the toolbox and  :beerchug:
Ruari Legg
Last post Sep 15, 2005, 05:50:31 PM
by 79coyotefrg
Last post Jan 06, 2006, 08:39:39 PM
by Duffil
Last post Jun 29, 2008, 10:35:53 AM
by THE ROCK
Last post Mar 27, 2009, 01:45:48 PM
by KYOTA
Last post Jan 09, 2012, 05:47:49 PM
by trekkerpaul
