PROS/CONS of.....
Started by dirtbag, October 28, 2004, 08:04:07 PM
dirtbag
..... a buggy leaf for the front?
Jared
buggy leaf in the front can  :moon:.  i dont see how it is possible...
FIREBALL
#2
 :headscratch: maybe angle of the frame (trying to make a place for the leaf to sit flat)
Torque flex (when you load up the front trying to climb up something, and the springs stretch out and you fall over backwards?)
I've seen a missing link (double shackle) setup on the front before. JimJob from Polock Pines used to use that setup on his front with 150 springs.
Con.....I already max out my 9012's easily.
Quote from: FIREBALL on October 28, 2004, 08:11:08 PM
Here's an example of what FIREBALL is talking about:
Con:  Buggy leafs dont actually help out much in the traction department.  They only let the drooping tire fall not be forced down which would increase traction.  They also have a tendency to allow side to side movement of the springs while turning.  In order to do a front buggy you would have to mount the shackle to the spring, which would be on the bottom of the frame which would make it stick down like a set of 8" shackles.
Pro:  You would look cool flexin on a ramp.
take a highspeed curve on the highway and take a :boxing:
dirtbag
thanks for the input, gentlemen, any more ideas?
Shamb
QuoteTorque flex (when you load up the front trying to climb up something, and the springs stretch out and you fall over backwards?)
This is your biggest CON,  IMHO
You dont need buggy's in the front. Slap those WAggys up there with some F150 shock towers and long shocks along with some longer shackles.. you'll have plenty of flex for nearly any trail out there.
UNBREAKABLE
That's how I roll
