Diff breather Leaking???
Started by guywithuglyyota, October 27, 2004, 04:06:36 PM
guywithuglyyota
I went wheelin the other day and this morning I noticed the front diff breather was oosing fluid out. I was only crawling around slow so what gives? I changed the fluid this morning and the stuff that was in there has the consistency of malt- o- meal, and was dark sludge.     :dunno:
dude thats water in the oil,  did you get it all out??   i always flush with diesel fuel then refill with 30 wgt run a couple miles drain that then refill with fresh
80-90wt
:wave:
better check your tranny, tcase and rear diff  :_oops: or you'll be :rivers:
MidgetMike
check every thing that you put fluid in, I didn'y check my tcase because the tranny didn't have any water in it but the t-case did and I also have gotten water in my clutch fliud resivior  :smack:  :turtle:  :usa:
guywithuglyyota
Thanks for the replies, the thing is I just purchased the truck, changed all the fluids EXCEPT the front diff (ran outa gear oil) the rear diff was fine, as was the tranny and t case. But the sludge that came out of the front diff would make the Valdez oil spill look weak. It was extremely thick! Ill do the diesel flush this weekend. I havent had the truck in water since I bought it. Does the front diff turn at all with in 2wd hi?
Nope.  Just do the diesel flush and refill with good old fashioned GL5.
Quote from: guywithuglyyota on October 28, 2004, 12:07:38 AM
it turns if the hubs are locked
