chevy springs
Started by 79coyotefrg, July 02, 2009, 01:23:13 PM
Quote from: 81_yota on October 12, 2010, 09:59:08 PM
ok 63s in front and rear and can run hysteer i had to clear this up my friend was saying only rear and wasnt worth it thanks for help ill proly stick with 33s for now
He was bein sarcastic. you can put them in front if you want the front hanger 2ft infront of the vehicle LOL
Sparkplug
Chevs r the best way to go for a budget. I did my whole rear suspension, including springs, hangers, u bolt flip, shocks, and shock mounts, for 67 bucks total.
Quote from: Sparkplug on October 12, 2010, 10:20:07 PM
:pokinit: I pait 80 bucks for my springs at Spaldings Auto in Spokane, WA. and they didnt even give me the right fricken springs I was looking for. I was bummed. but Ill rock 'em for now.
I was told that the 88-99 Tahoes had the 63's as well and being a tahoe they'd be more "broken in" due to being a heavier vehicle. the guy said oh i always ask for those springs on that vehicle they work better. come to find out after i get all the way home... yeah 54" Chevies :( I was bummed.
But i think they'll work good. they are 4leaf w/ an overload. arent F150s around that length too?
twistedtoy92
always take a tape with ya!
46&2
I traded 12 Coronas for my 63s with 4wd shackles. :gap:
yota4x4sc
ha this dude buyin a couch at my buddys house said he had a bunch of random leafs at his house, so he droped em off and i dont know wat the fronts were but they were like 4 inch longer than marlin fronts, well anyways they flexed like a savage..there were a bunch of very very thin leafs..so sick for some random free leafs. then used  a set of 2wd 63s in the rear from pick n scrape for 68 bucks. than runner flexed savage for being on some random junkyard leafs!! :yikes: :attention:
birfection
I purchased a set of Energy Suspension bushings for my 63" chevies. I was at Tractor Supply looking for bolts to use in mounting the springs. They didn't have any 9/16 bolts, so I bought 3/4 because they were the same size as the metal bushings Energy gives you to put inside the urethane bushing. Is there a problem not running  the metal bushing and just sliding the 3/4 bolt right through the urethane bushing? Thanks for any help!
TITAN CRUSHER      http://www.youtube.com/watch?v=v6qnDVgWBSA
1980 Pickup: 22RE (bored 20 over, OS Valves, 261 cam, ported and polished intake/exhaust, Pacesetter long-tube header), L52 5 Speed, 6 leaf RUF, 63" Chevies, Hi-steer, 35 x 12.5 Maxxis Creepy Crawlers, Dual 2.28 cases, Detroit Front, Welded Rear, 5.29s
4RunnerChevy
Try running a bolt that completely runs on the shoulder.  Most threads are smaller on OD, in the threads. Threads will chew up bushings, and shackle holes.  Run a nylon nut, or stover, so you dont bend the shackle.  Be prepared for premature wear on the bushing.  If you can't find the 9/16 hardware then I can set you up.
Zane
can anyone give me an exact model to get the chevy shackles off of? i got my 63s from a friends, and Im not sure what chevy to get shackles from.
88-99 Silverado 1500 should have those shackles. they are reversed on the trucks.
superyoat
#70
i had an 2004 1500 in the shop the other day and it had 3 leaf 63" springs on it. so what is the difference between that and the 77-98 springs
1985 4runner. 4.3TBI, ford 9" rear w/detroit, toy front w/detroit, longfield shafts, alcan springs, dual cases.
twistedtoy92
Quote from: superyoat on July 06, 2011, 12:57:19 PM
the newer ones are thicker.... i grabbed a set of those same springs (2004) and the guy told me I wanted a earlier set. the spring rate works way better for a light truck :beerchug:
wakkjobb
Don'tcha love it when people tell you what you'll like?   :shake:
I love my 63s; got em from u-pull for about $40; came from some 2wd Chevy/GMC trucks. It's easier to pull the right-side from 2 trucks instead of fighting the fuel tank. Trust me.   :yesnod:
I've been looking into F150 springs for whatever I build next just to see what the differences are between them and the Chevy springs (besides almost a foot in length).
>>Dan
yotacrawler1
hey if anyone has some pics of there 63s on a short bed regular cab pick up, preferably pics of the hanger.  and maybe some clearance pics, or whatever u got would be nice hahah and if ur runnin double shackle or not
46&2
Quote from: wakkjobb on July 08, 2011, 08:58:30 PM
>>Dan
F150 springs are great too. This is AJ's runner with F150s a few years ago. I was impressed. I think he bent them shortly after this though.
SloCrawler
f150 and ruf, I talk to alot of peeps that went this way after chevys because their too long
46&2
Quote from: SloCrawler on September 28, 2011, 02:25:32 PM
Length is their only downfall, especially on bobbed trucks. They are perfect for 4runners though or people who want to keep their beds stock.
superyota
I love my chevy's.  my bed is bobbed 11 inches and wheelbase stretched to 111 inches.  I've never had any problems with them being too long or anchoring on rocks.
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
46&2
Yeah I know there are plenty of people that run them with bobbed beds. Seems to be the biggest complaint though. Looks great on your rig superyota.
superyota
ABD Motorsports
#4475
KK6QDW
BadnewsBob
#80
I just did this swap to my 84 xtra cab last month. I used the chevy front spring hangers and 6" shackles on the rear, I also moved mine back making my wheelbase longer. I have 2" blocks on it also it gave me about 5"s of lift, I didn't change anything else except 6.5" longer drive shaft. I then moved my rear springs to the front with TG SAS mounts that matched the rear lift just right.This moved my front axle forward 2" my truck now has 115" wheelbase. I love it on the climbs, Of course you can't do this with a bed without major surgery. The front clears my 35" BFGs no problem.
I don't know why people say they are too long, I don't have any problems climbing walls and I follow my buddies around everywherer they go in their linked rigs, And it is the best riding yota I've been in except a linked truck.
AE2 USN ret
No matter where ya go..... there ya are.
Hillbilly Offroad
84 xtra cab on 63" chevies and RUF 35" KM2s 22R 5 speed DTC 5.29s Locked front and rear.
BadnewsBob
Another Pic
AE2 USN ret
Hillbilly Offroad
Rob84pkup
I love my 63s. I run a double shackle set up as well.
Mytattootears
#83
Hey just wondering what size shocks everyone is using when doing the 63 and the ruf? 12 or 14"?
46&2
Quote from: Mytattootears on November 19, 2011, 05:48:47 AM
I run 14s like this /\ in the rear but I think 12s would work too depending on how you mount them.
Mytattootears
Quote from: 46&2 on November 20, 2011, 07:36:49 PM
My rear is mounted like /\ so I'll get some 14 in the rear and 12s with the rufs
46&2
Quote from: Mytattootears on November 20, 2011, 07:43:40 PM
Doesn't hurt to take measurements to be sure.
twistedtoy92
i frenched my 63's into the frame so I had to ditch the 14''s and install 12''s at less of an angle so I am now actually using the damn shock
builttoabuse
Quote from: 79coyotefrg on July 02, 2009, 01:23:13 PM
yo i found your thread makes alot of sence i understand completly what you were saying : )thanks
toy obsessed!
waynescamo
#89
thanks for all the info. defitnitley gonna consider this
