Author Topic: Output Seal....  (Read 2229 times)
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
Output Seal....
« on: Jun 28, 2009, 12:05:04 AM »
After 23 years, I just noticed that the rear transfer output seal is leaking....
(I assume it's the seal, but it could be that the flange nut got loose again)
Anyway,  how many years will the ECOSEAL last?
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
Re: Output Seal....
« Reply #1 on: Jun 28, 2009, 12:44:21 AM »
probably longer :p
come one, the stupid government will ong have outlawed gas vehicles by then... we will have hovercars and jetsons cars by then
REG535
  • Turtle Points: -287
  • Male Posts: 1,083
  • Member since Jul '07
  • Shes traveling to many celestial worlds
    • Buy me a cigar
Re: Output Seal....
« Reply #2 on: Jun 29, 2009, 11:19:33 PM »
i will still drive my truck regardless what they say or do  :disturbed:
brainlessfool
  • Turtle Points: 2730
  • Male Posts: 4,207
  • Member since Jun '02
    • Buy me a cigar
Re: Output Seal....
« Reply #3 on: Jun 30, 2009, 05:32:40 PM »
porbley loose again.  :twocents:
emsvitil [OP]
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
Re: Output Seal....
« Reply #4 on: Jul 02, 2009, 03:15:33 PM »
Flange nut is still tight..........
So I guess I'll have to get the seal.
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
emsvitil [OP]
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
Re: Output Seal....
« Reply #5 on: Jul 13, 2009, 01:53:44 PM »
Ordered the seal........
How much oil is going to come out when I pop out the old one?
Is it worth the trouble to raise the rear end of the truck to minimize any oil oozing?
thanks
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
  • Administrator
  • Turtle Points: 2158
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
Re: Output Seal....
« Reply #6 on: Jul 13, 2009, 02:10:03 PM »
I don't know how many miles or months you will get out of the seal. We do feel it is made of better material and of a better design than the stock Toyota seal. Of course even a Toyota seal won't make it out your drive way if it's installed wrong, so just make sure you follow these recommended steps to maximize the life of your EcoSeal:
1) Take some 350 grit or so sand paper and rough up the sealing surface on your flange. Seals cannot break into their sealing surface if the sealing surface is as smooth as ice. Make at least 20 rotations of the sand paper on the surface of the flange where the previous seal sealed, making sure there is sufficient roughage for the seal to wear into.
2) Degrease the inner splines of the flange and also the splines on your output shaft, and then apply silicone to the inner splines of the flange. We recommend using Super Gray or Ultra Black. We avoid Orange and Bluesilicon like a plague. You might get away with Red silicon but we consider it inferior to Gray.
3) Always always always apply grease to the inner diameter of the seal before installation. If you forget to do this and have already installed the seal, you can still apply grease with the seal installed but it will be much harder to do so beings you will have a siliconed output shaft right in the way that you don't want to touch.
4) Optionally, you could also add silicone to the back side of the washer before you install the nut, so that the silicone on the washer mates to the flange where the splines are. But this isn't too necessary if the splines were degreased well enough.
As for the oil, no oil will come out assuming your t/case is not over filled and the transfer case itself is nearly horizontal. If any oil does come out, it won't be much, maybe just some residual oil that might run down the housing, nothing a small shop rag can't handle.
Let us know how it works out for ya!
Thanks
Mike
emsvitil [OP]
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
WARNING , WARNING, WARNING.............
« Reply #7 on: Jul 23, 2009, 11:09:51 PM »
When putting the flange back on slip it in and make sure it goes all the way in before applying RTV....
(The dust flange should overlap the machined part on the aluminum)
So you don't do the following:
Apply RTV
Insert
Doesn't seem to go all the way in
Get impact wrench to make it go in
It still doesn't go in.........
 :yikes:
You end up taking off the extension housing and find the speedo gear had come off the ball and rotated a little.
The impact wrench had tried to make a new groove for the ball bearing in the gear.  :smack:
You needed gear puller to get gear off, then had to smooth out the gouge the ball bearing made in the gear.
If the flange doesn't go all the way back in, you may still need to take off the housing, but at least you won't need a gear puller.........
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: Output Seal....
« Reply #8 on: Jul 24, 2009, 09:44:54 AM »
:yikes:
Last post Sep 19, 2007, 10:36:15 PM
by Hammerhead
Last post Sep 15, 2007, 07:55:39 AM
by eporter
Last post May 12, 2009, 07:12:13 PM
by hytenor
Last post Jan 31, 2010, 05:30:34 PM
by Yota87Truck
Last post Oct 31, 2010, 03:56:29 PM
by dntsdad
