Help me out- DIY antenna mount
Started by jrock, June 26, 2009, 08:27:12 PM
jrock
A VERY gracious friend has given me an antenna for my old CB. Now I need help putting it together.  :biggthumpup:
I have a whip antenna with it's ball mount. I have no idea how to wire this. The Radio Shack RG-58 Coax Cable is throwing me off. The ends don't fit the whip. The 4th picture is the wire ends I thought I would use to attach the Coax Cable to the antenna.  :dunno:
Pictures: 1- CB, 2- Coax Cable end and ball mount end, 3- DIY mount, 4- Wire ends.
jrock
Pictures.
jrock
fordh8r
Where's the plastic base for the ball mount? If you're missing it, you'll need a new ball mount. That base is the insulator that keeps the antenna circuit (center wire in coax cable) from shorting out to the body. If you short the antenna circuit wire to ground it will damage the radio. The only part of the coax that gets grounded is the braded shielding wire.  :yesnod:
Also the hole in your bracket will need to be a lot bigger so that no part of the antenna circuit contacts it except for the braided shield wire for ground.
jrock
Plastic was all busted up and missing pieces. Could I make one?
So the positive goes to the 3/8 center and the negative goes where? This is getting mounted behind the driver at the head of the bed.
jrock
Maybe this?
fordh8r
I suppose you could make one but if you don't know what it looks like, how would you know what to make? A new ball mount is not very expensive at Radio Shack or any other electronics place. Plus it will have instructions on hooking it up and probably how to set up the cable for match tuning the antenna.  :thumbs:
Yes, the solid wire connects to the center of that stem at the bottom of the ball mount with a ring terminal on the wire and then screwed to the stem. The ground will usually go to one of the mounting screws from the base of the the ball mount where it attaches to the body or other grounded metal surface.
EDIT: your drawing looks like it will work.  :thumbs:
jrock
Finally found the picture I was looking for. Ford8r, when your right your right. I will be going back to Radio Shack for the ball mount.
http://www.firestik.com/Instl-Art/k14bm-inst.jpg
fordh8r
Your radio will thank you for it.  :yupyup: :biggthumpup:
jrock
jrock
Oh, what is a good fuse size for a cb?
fordh8r
have it tuned with an swr meter
also, you can get that stuff cheper at a truck stop, i know thye have higher quality stuff than radio shack, and its cheaper too, at the pilot gas stations near my other crib
jrock
Quote from: fordh8r on June 26, 2009, 09:57:35 PM
Most likely a 5a or 7.5a.  :thumbs:
Wow, guy at Radio Shack was way off. I have 2amp. I'll change that.
Quote from: jimbo74 on June 26, 2009, 09:58:03 PM
also, you can get that stuff cheaper at a truck stop, i know thye have higher quality stuff than radio shack, and its cheaper too, at the pilot gas stations near my other crib
I will get better stuff when I get a better CB. Radio Shack is way closer than any truck or cb shop.
fordh8r
Quote from: jrock on June 26, 2009, 10:01:39 PM
If the 2 amp works without blowing from normal use then use it. If it blows everytime you use the radio then put the larger fuse in it. I wouldn't go bigger than 10a since the power wires probably aren't big enough to handle much more if it should short out.
jrock
thought you wre out in stockton? tons of truck stops out there, its all good though, radio shack works, i have an swr meter, but have no idea how to use it, lol -- but you are welcomed to it, i know you it will require a small interconnct wire as well..... also, check out fry's electronics if you re out this way
jrock
Well all in.  :twocents: Radio Shack ball mounts suck! Plastic base and it turns when it's all tightened up  :thumbdown: . So a new question, my signal meter says strong but I hear nothing. On ch9, with the volume at max, and my ear to the speaker I can BARELY make out voices. What's wrong?
fordh8r
What sorta settings/functions do you have on that radio? The large nut on the antenna base...is it touching any grounded metal? Pictures of install?  :headscratch:
jrock
Quote from: fordh8r on June 27, 2009, 11:07:28 PM
I can get pictures tomorrow but as far as I can tell it is not touching. The radio has a Squelch, Ch and Volume.
jrock
 :help: I think my ground screw might not be touching the beds bare metal.
jrock
I was stupid when I measured. Temp fix.
fordh8r
First things first, ...is that tape on the bed rail with the spring up against it? You'll have to move that mount because that spring will wear through that tape in no time and allow the spring to short out.  :thumbdown:
Next, if you have an Ohm Meter, check across the terminals in the coax connector that connects to the back of the radio. The center terminal should not be grounded but the outer terminal should. If the center terminal shows to be grounded you have a problem to fix. If the outer terminal doesn't show to be grounded you have a problem.
Just hope the radio isn't damaged already from a previous installation.  :crossed:
jrock
I'll have to find an Ohm meter and I'll get back to ya  :crossed: . I know the duck tape is retarded but this setup is temp. until I can afford a real setup.  :hammerhead:
jrock
PS. What is the closest Cb shop that will carry a mic? What should it cost?
fordh8r
jrock
unclejpl4x4
have you decided on what kind of mic you want ?    if your trucks noisy like mine i would get a noise cancellation mic
jrock
fordh8r
Quote from: jrock on June 28, 2009, 08:15:34 PM
No.  :thumbdown: Not yet.
That's probably why you don't hear anything.  :psss:  Most radios won't even make noise of any kind unless the mic is connected.  :slap:
