1991 4Runner SAS, ARB's
Started by howdy, June 26, 2009, 08:01:59 PM
howdy
1991 Toyota 4Runner
4 Door
White
Blue Interior
Automatic
3.0 with 12,000 miles
Cruise Control
A/C
Power Windows
Power Door Locks
Rear Heat
Front End
1982 Front Toyota Axle
Marlin Crawler front SAS with 4" Springs
Marlin Crawler High Steer Crossover Steering Kit
12" Bilstein 5125 Shocks
1.5" Wheel Spacers
U-Bolt Flip
Knuckle Ball Gussets
Upper Axle Reinforcement Gusset
Diff Armor
Marlin Crawler Knuckle Service Kit With Wheel Bearings
Marlin Crawler Spindle Nut Kit
Marlin Crawler Heavy Duty Front Inner Axle Seals
Trail Gear Backing Plate Eliminator
Trail Gear Spindle Stud Kit
Trail Gear Rock-Ring Knuckle Felt Protectors
ASCO Manual Locking Hubs
Balanced CV shaft
High Pinion 3rd Member with ARB and 5.29 Gears Set Up By Marlin Crawler
Rear End
Stock 1991 IFS Rear End
Marlin Crawler Rear Leaf Conversion With 5" Springs
U-Bolt Flip
Diff Protection
V6 3rd Member with ARB and 5.29 Gears Set Up By Marlin Crawler
MISC
4 37" Goodyear MTR's with 90% Tread Remaining Mounted on 15x10 Aluminum Rims
1 37" Goodyear MTR with 60% Tread Remaining Mounted on 15x10 Aluminum Rim
ARB Compressor
Marlin Crawler Front Winch Bumper
Marlin Crawler Rear Bumper
Trail Gear Rock Sliders With Gusset Kit
Marker Light/Turn Signal Modification
Steering box has been moved forward 2"
130 Amp alternator upgrade
Upgraded 4ga charge wiring
Die Hard P4 Battery (Made by Odyssey)
Brand new 9500 Power plant winch
Its been a clean well running rig. Its only been on 3 runs. 2 snow runs and a run up Strawberry trail, so the springs are just getting broken in hence the reason the front is sitting a little high. The only known problems are:
Electric mirrors don't work. I have replaced the switch with no luck.
Cracked front grill
Small oil leak from right rear valve cover
$8500 obo
916-221-1064
Located in Folsom, Ca
howdy
If there is not much interest in a complete rig I will start parting it out the rims/tires, winch, 3rd members, compressor in a few weeks.
kauaikid
that's a beautiful 4runner, just what I need  :driving: .  If I could sell my truck in time I'd pick this up in a heart beat.  Good luck on the sale
84 longbed, lc eng. top end kit, dual cases w/ 4.7 in rear, arb's front w/high pinion and rear with v6 diff., 5.29's w/ 35s, all-pro long travel 4" and much more
howdy
Quote from: kauaikid on June 27, 2009, 09:42:38 PM
Thanks...Its been a great rig so far. I have had it done since January and have only used it off road 3 times, so most of the time it sits in the garage. I missed my clubs annual Rubicon run and the trip to Fordyce yesterday. I am just not getting the use out of it I had hoped with my work/home schedule.
jamesyz250
yota_krawler
why did you delete the posting on CL?
sanger4
If you decide to part it out I will take the Front and Rear 3rd's the compressor and maybe some other little stuff.  Let me know...thanks.
howdy
Quote from: Hunter on June 28, 2009, 11:12:19 AM
Oh sorry I forgot I did delete it. I tried to make some changes and add some more info and CL didn't want to play. It wouldn't let me repost until about 2pm today. So I will repost then and include the new link. Maybe I will just try and add pics here.
howdy
Quote from: sanger4 on June 28, 2009, 11:19:08 AM
I will keep you in mind...thanks
AaronB
Dont part it, someone will buy it. do you have it on Pirate?
howdy
Quote from: Aaronb on June 28, 2009, 11:41:04 AM
I did just put it on POR. Sometimes they can be weird over then since they are so "hardcore" They always complain they can build the same rig for $2500... LOL
usmc_black_85
yeah you could build the same rig with all used parts for cheap but it would take you for ever to get all the parts and build it and tons of wasted time searching plus its a pain. sick rig bump
"I KNOW I KNOW ITS A JEEP THING THATS WHY I DRIVE A TOYOTA"
"HEY BARBIE CALLED SHE SAYS SHE WANTS HER JEEP BACK"
4Runtoy
#12
Would you consider any trades? I have a 1985 toy extended cab new suspension rebuilt engine 500 miles ago, brand new 33" and new wheels. I also have a 1985 4runnrer very clean sitting on brand new 35 mt and 4" lift,  and a 1980 toy 4x4 extra clean, brand new everything from Marlin crawler., never taking it offroad yet.
picoguard
I'll trade,
1972 FJ55
1974 International Scout II
Marlin Crawler Dual Cases
Rubicrawler
Do you still have it?  I pm'd you on Pirate.  Give me a call when you get a chance.
Mark
Mark Langford
Brentwood, CA
'91 4Runner 3.0, Auto, Inchworm dual case w/Marlin 4.7 gears, Marlin SAS & rear leafs, 30 spline 4340 Longfields & hub gears.  Marlin Hi-Pinion ft. diff, 5.29's and ARB's.  159:1 with an Auto ROCKS!
4Runtoy
Have you sold this thing... :sleeping: .......an answer would help.  :maddest:
trucha
dude! ur rigs r bad ass....all of them :thumbs:
4Runtoy
Thanks, the 85 pu (red) its for sale, Im asking $4750 obo, has a 22Re just rebuild 500 miles ago top and bottom end(2.5 months ago) new clutch and fly wheel, water pump, timing chain, 4.70 gear ratio front and rear axles, new suspension 7" lift, new bushings, brakes,the tires on the picture are different though, it has a brand new 33" mt with brand new white spoke rims. inside very clean and clean title.
bigarms23
are you running stock birfields or longs
4Runtoy
howdy
Sorry...I have been out of town for 2 weeks. I am back and ready to get this thing sold. I just got it smogged today and have the clear title in hand.
Thanks for the trade offer guys. There are a couple cool rigs there I would consider, but its time to cash out and pay off some bills.
howdy
Rubicrawler
Quote from: howdy on July 26, 2009, 10:43:42 AM
Sold
Yep, my wife and I are the new happy owners!  Thanks Howdy!
Mark Langford
Brentwood, CA
starrunner
BEER PONG! you can play me, but cant beat me
bkn
that was a clean one.............
