Mounting wood racks in the bed
Started by NorCalToy, May 12, 2009, 09:54:56 PM
NorCalToy
Anybody have any ideas how to mount woodracks in the bed? the lack of utility holes makes it somewhat difficult to produce a sturdy rack...i built some mounts for now, that might be temporary pending any ideas shown here. ill have pics in the morning
:flamer: IFS
superyota
do you mean a headache rack, or a full lumber rack?
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
NorCalToy
i mean like wooden bedsides that go above the bedsides so you can stack wood against them.
all iv got is a crappy paint edit of a pic i took when i had wood in the bed
does that make sense?
:flamer: IFS
NorCalToy
well i think they turned out pretty freakin similar
and how i did the mounts
:flamer: IFS
unclejpl4x4
ya i think your only option is to add pockets like above  U can screw them like shown or screw or weld them on the top of bed sides.
:slap: Nm u allready did
junya92toy
I would get angle and bolt it down to the bed rails, them mount the wood rack off of that. its how i mounted my rack. even if you mount a stack pocket like you posted, it would be stronger. Like 1/8 angle would be good. 3/16 maybe even 1/4. I bet if you weld or bolt the pocket to the sheet metal after time it will tear on you
NorCalToy
Quote from: jerry92toy on May 13, 2009, 04:59:10 PM
yea im sure it will tear. its temporary for now. i think im gonna get a longer piece of angle iron and weld that bracket to it and then mount it with  at least 2 bolts to teh bed rail.
:flamer: IFS
catfish
use angle all the way around, make slots for removable sides or build a tubing box welded to the angle and just set the whole thing on the truck when you need it
