My 98 Toyota Tacoma TRD V6 with a 5" lift
Started by Yota87Truck, May 10, 2009, 08:40:42 PM
Yota87Truck
Hells Revenge cont...
Yota87Truck
Worked on my bumper some more.  Hopefully I will be finished with it soon.
Also my bosses dad made me a custom pry and alignment bar.
Yota87Truck
painted hitch cover
Yota87Truck
Finally got the bumper painted and on.  Now I just need to modify the hitch.
Mega Baby Huey
bump for the sweet truck!!!!  :biggthumpup:
you're welcome!!!  :smooch:
The Art of Flying is Actually Quite Simple! You Just Have to Throw Yourself at the Ground and Miss!!!                                   All This Global Warming is Wearing Out My Snow Shovel!!!                        Paved Roads: Just Another Example of Useless Government Spending!                                          Toyota. Moving forward... even if you don't want to...
My Old Toy
Yota87Truck
Mega Baby Huey
My Old Toy
Yota87Truck
Next plans for my rear bumper:
Yota87Truck
Wow it's been a while since I have updated.
My rear Bumper and Hitch are finished.
I have a set of Off road Tires 33x10.5 R15 BFG KM2
My front bumper got painted and finished enough for moab.  I still need to tweak it and add the top plate
Yota87Truck
More
Yota87Truck
Also fixed my door lock cylinder finally. It has had fits since I bought the truck.  I can now unlock the passenger door with the key from the driver side.  After tearing it apart no wonder it didn't work.  2 of the tumblers were messed up.  Overall a way easier fix than expected.  If I were to do it again I would have just had the locksmith fix my broken one instead of buying from toyota :moon: and having the locksmith re key it. :smack:  OH well
Yota87Truck
Yota87Truck
Moab 2011 Pics (way late)
Yota87Truck
#46
More pics...
And the last pic is the famous yearly Moab brake job.  Moab 2010 I had to do my front brakes, this year my back brakes.  But come to find out it was actually my e brake cable that seized causing me to think I needed new brakes.
sabatoa1
You should come run the snakes at five mile with us sun. We have a big group going and I think you will have a blast.
1984 4runner buggy 22r on pane, duals, hydro assist, spool front, spool rear, 37x13x16 Creepy Crawlers.
http://board.marlincrawler.com/index.php?topic=89989.0
Yota87Truck
Sweet.  I'll see what I can do. What time?, and where are you meeting?
yotaneck13
Yota87Truck
#50
Did this a while back.  Figured I'd throw up some pics of it.  Funny I have had my green hitch cover on my truck for a while now (about a year ago I built it) built from ballistic fab skulls and now they sell hitch covers, which are a little larger than the ones I have made.
Here is a build of the one I made for my wife to throw on when she drives my truck.
My hitch cover:
My recent purchased tool!
wire:
Modified Hitch:
burnt hornets nest:
burnt hornets nest2:
before sanding, this skull sat for a while before I got around to making it.
after quick sanding
holes filled and ground smooth
holes sanded smooth
welded onto hitch end
painted black
painted end pink
Yota87Truck
Last weekend I started building my sliders
Tools I will be using for build:
Lincoln 140 Welder
Angle Grinder
Sander
Specs 80" long by 6" wide 1-5/8" diameter
75% of materials rough cut  (this is what came out of 1 length of tube)
made a template out of painters tape, trial and error until I found what worked.  The first cuts I basically made in 2 cuts but it created more of a V shape
After working with my cuts I found it was better to cut this way.  I actually used a combination of the two cuts and cut at this angle with 2 cuts like first.
After making the cuts you have to take a grinder to the tips so the curvature of the tube matches.  I just grabbed a spare piece an ground it til it matched.  I just eyeballed everything like matching the 2 ends of the connector pipes.  Seemed to work fine.  Everything came out great for not owning a notcher.
On the agenda for tomorrow, patch father in laws roof and sand, weld and prime at least one slider.
Yota87Truck
Got one side welded together:
Still one side to go, paint and legs.
Yota87Truck
#54
Sliders welded on
Yota87Truck
Definitely a learning experience to build my own.  And the part that I thought was going to take the longest was actually the easiest and the part I thought would be easy took a while.  If you have the money it is definably worth it to buy them.  Although this depends on the tools available to you.  What took me the longest was notching the pipe.  I did not expect this to take as long as it did.  welding it onto the truck I thought was going to be difficult, but I just tack welded it on the bottom of the sliders to the frame.  Then I tacked all the legs and sliders on and then bent it until it broke my tack welds off the frame.  I welded final welded up everything (moving frequently) and painted and installed.
These took me about 3 Saturday projects.  Non pressure, probably 3 half days to install.
daniresch
the sliders look great, way to do them yourself!
Yota87Truck
Next project for Moab is suspension:
U-bolt flip kit
bump stops
custom leafs (current combined with 02 leaf pack)
new shock mounts ( /\ style )
possible extended brake line (Haven't looked at mine, had blocks on it when purchased but ya never know)
t case protection
modify front bumper
and with time add to rear bumper (quarter panel protection)
Mega Baby Huey
you gonna put your front bumper on before moab?
My Old Toy
Yota87Truck
#59
Regardless whether I get around to modifying it I will put it on for Moab.
